[GRASS-user] How to sum a hundred of raster maps using r.mapcalc
    Miguel Carrero
    miguel.carrero.pazos at gmail.com
    Fri Sep  9 09:18:24 PDT 2016
Hi all,
Thanks to everyone for the help. I’ve tried with g.list, and pass a file with all map names in r.mapcalp, but realised that there is a limit on space to sum a high number of maps at the same time. So, I’m going to have a look to r.series.
Cheers,
Miguel.
De: Laurent C.
Enviado: viernes, 9 de septiembre de 2016 16:09
Para: Veronica Andreo
CC: Miguel Carrero; grass-user
Asunto: Re: [GRASS-user] How to sum a hundred of raster maps using r.mapcalc
2016-09-08 12:32 GMT-05:00 Veronica Andreo <veroandreo en gmail.com>:
> Hello,
> You can use r.series for that and pass the list of maps that you get with
> g.list directly into r.series using back ticks, or you can also pass a file
> with all map names. Check the manual for more examples:
> https://grass.osgeo.org/grass73/manuals/r.series.html
Hello,
Interesting, I always used mapcalc for this. Do you know what are the
advantages of using r.series instead of mapcalc for this type of job?
Laurent
------------ próxima parte ------------
Se ha borrado un adjunto en formato HTML...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160909/954d674a/attachment.html>
