[GRASS-user] Raster renamed but d.rast does not find it
Micha Silver
micha at arava.co.il
Fri Sep 9 12:07:21 PDT 2016
------ Original Message ------ Subject: [GRASS-user] Raster renamed but
d.rast does not find it Date: Fri, 9 Sep 2016 11:46:20 -0700 (PDT) To:
Grass-user From: Rich Shepard
> GRASS-7.3. With 'g.rename rast=hdr,bare_earth_2010' I renamed the
> raster
> file called 'hdr' to 'bare_earth_2010'.
> In the console:
>> g.list type=raster
> bare_earth_2010
> highest_hit_2010
> shows the two renamed raster files.
> Using the GUI I try to display bare_earth_2010 and the Layer Manager
> console window displays:
> Failed to run command 'd.rast map=hdr at topography'. Details:
But you just renamed it to bare_earth_2010 ??
Whenever I make fundamental changes at the command prompt, I just stop
the GUI and restart it with g.gui.
(Recall your previous post about the diff between stopping GRASS
altogether, or just closing the GUI)
> GRASS_INFO_ERROR(4555,1): Raster map <hdr at topography> not found
> GRASS_INFO_END(4555,1) Failed to run command 'd.rast
> GRASS_INFO_ERROR(4556,1): Raster map <hdr at topography> not found
> GRASS_INFO_END(4556,1) Failed to run command 'd.rast
> GRASS_INFO_ERROR(4724,1): Raster map <hdr at topography> not found
> GRASS_INFO_END(4724,1)
> d.rast from the command line fails, too:
>> d.rast map=bare_earth_2010
> ERROR: Neither MONITOR (managed by d.mon command) nor
> GRASS_RENDER_IMMEDIATE (used for direct rendering) defined
> How do I correct this name mis-match?
> Rich
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160909/cb2026d7/attachment.html>
