[GRASS-user] Location not displayed when grass started
    Blumentrath, Stefan
    Stefan.Blumentrath at nina.no
    Wed Sep 14 11:19:46 PDT 2016
Hei Rich,
Good to see that you don`t give up even if you ran into several issues or undocumented peculiarities.
As for the grass database:
I am not sure if I understand your question well, but in principle only GRASS itself should create or delete files and folders within the GRASS database.
At import data is converted into GRASS format, and GRASS creates the files and folders needed for that.
In short, do not write or delete files and folders in your GRASS database "manually" you can messup your DB.
You would not save shape files in the FGDB directory either, would you?
Cheers
Stefan
-----Original Message-----
From: grass-user [mailto:grass-user-bounces at lists.osgeo.org] On Behalf Of Rich Shepard
Sent: 14. september 2016 19:49
To: grass-user at lists.osgeo.org
Subject: [GRASS-user] Location not displayed when grass started
   I want to understand how grass7x finds data when starting.
   In my grass database, ~/data/grassdata/, I created a subdirectory named ODOT2014.gdb with all the OpenFileGDB files in it. However, when grass7.x starts it does not display that location in the left-side window.
   Grass will also not create a substitute location because location names created by the GUI cannot contain certain characters, including a period.
   I want to create a separate location for these data then reproject them from the target project directory.
TIA,
Rich
grass-user mailing list
http://lists.osgeo.org/mailman/listinfo/grass-user
