[GRASS-user] Importing data in .atx/.gdb format
Markus Metz
markus.metz.giswork at gmail.com
Wed Sep 14 14:14:25 PDT 2016
On Wed, Sep 14, 2016 at 10:39 PM, Rich Shepard <rshepard at appl-ecosys.com> wrote:
> On Wed, 14 Sep 2016, Markus Metz wrote:
>> Using CLI, what is the output of v.in.ogr
>> input=~/data/grassdata/or-trans/a00000001.gdbtable -l ?
Getting closer...
>> v.in.ogr input=~/data/grassdata/ODOT2014.gdb/a00000001.gdbtable -l
> Data source </home/rshepard/data/grassdata/ODOT2014.gdb/a00000001.gdbtable>
> (format 'OpenFileGDB') contains 1 layers:
> GDB_SystemCatalog
>> v.in.ogr input=~/data/grassdata/ODOT2014.gdb/a00000002.gdbtable -l
> Data source </home/rshepard/data/grassdata/ODOT2014.gdb/a00000002.gdbtable>
> GDB_DBTune
>> v.in.ogr input=~/data/grassdata/ODOT2014.gdb/a00000003.gdbtable -l
> Data source </home/rshepard/data/grassdata/ODOT2014.gdb/a00000003.gdbtable>
> GDB_SpatialRefs
>> v.in.ogr input=~/data/grassdata/ODOT2014.gdb/a00000004.gdbtable -l
> Data source </home/rshepard/data/grassdata/ODOT2014.gdb/a00000004.gdbtable>
> GDB_Items
>> v.in.ogr input=~/data/grassdata/ODOT2014.gdb/a00000005.gdbtable -l
> Data source </home/rshepard/data/grassdata/ODOT2014.gdb/a00000005.gdbtable>
> GDB_ItemRelationships
>> v.in.ogr input=~/data/grassdata/ODOT2014.gdb/a00000006.gdbtable -l
> Data source </home/rshepard/data/grassdata/ODOT2014.gdb/a00000006.gdbtable>
> GDB_ItemRelationshipTypes
>> v.in.ogr input=~/data/grassdata/ODOT2014.gdb/a00000007.gdbtable -l
> Data source </home/rshepard/data/grassdata/ODOT2014.gdb/a00000007.gdbtable>
> GDB_ItemTypes
>> v.in.ogr input=~/data/grassdata/ODOT2014.gdb/a00000009.gdbtable -l
> Data source </home/rshepard/data/grassdata/ODOT2014.gdb/a00000009.gdbtable>
> OR_Trans_for_Public_Distribution_8_2014
The output of v.in.ogr input=~/data/grassdata/ODOT2014.gdb -l would be
GDB_SystemCatalog
GDB_DBTune
GDB_SpatialRefs <--- interesting
GDB_Items
GDB_ItemTypes
can you confirm?
>> This tells you only that the coordinate reference system of the input
>> data is unknown. It might be Lat/Lon or something else. You can try to
>> 1) import the data into a Lat/Lon location, reproject to the target
>> location and check if the geolocation is ok
> Tried this without success.
>> 2) ask the data provider about the coordinate reference system for
>> this data source
> According to the metadata.xml file: the projection is Lambert Conformal
> Conic stdparll-1 43.000000
> stdparll-2 45.500000
> longitude cm -120.500000
> latprj 41.750000
> cell res. 0.004096m (1 International feet)
> North American Datum of 1983
> Which is very close to, but not exactly the same standard paralles as the
> project location.
Try to create a location with the metadata.xml info, or better with
the WKT description you obtained, then import the needed layers to
this location, finally reproject the data to the target location,
check geolocation.
Markus M
