[GRASS-user] Importing data in .atx/.gdb format [RESOLVED ...	REALLY!]
    Even Rouault
    even.rouault at spatialys.com
    Thu Sep 15 11:23:58 PDT 2016
Le jeudi 15 septembre 2016 20:22:01, Rich Shepard a écrit :
> On Thu, 15 Sep 2016, Even Rouault wrote:
> > What do you exactly mean by "fail" ? Does it report something like
> > FAILURE:
> > Unable to open datasource `foo.gdb' with the following drivers.
> >  -> PCIDSK
> >  -> netCDF
> >  -> JP2KAK
> Even,
>    Yep. ogrinfo reported it could not open the data source with any driver.
> And the GUI displayed no file name when I tried importing it with v.in.ogr.
> > (Side note: metadata.xml is not something required in a file geodatabase,
> > so this is completely ignored by the driver. Must be something specific
> > to your data provider. The projection info used by the driver is stored
> > in one of the "system" .gdb tables)
>    I recognize this but wanted to see if there was a different EPSG code in
> the metadata.
> > Do you get error messages ? Otherwise adding "--debug on" (double dash
> > before debug) to the ogrinfo command line might give extra messages.
> > Otherwise you could share the dataset or a link to it, and could have a
> > look.
>    First try:
> $ ogrinfo --debug on -al -so .
> OGR: OGROpen(.) failed.
> FAILURE:
> Unable to open datasource .' with the following drivers.
>    -> ESRI Shapefile
>    -> MapInfo File
Hum, '.' will only work if you work with GDAL compiled from today sources. You
need to specify a directory name ending with .gdb
> etc.
>    Second try:
> $ ogrinfo --debug on -al -so ~/data/grassdata/ODOT2014/hwynet_2015/
Same here: it doesn't end with .gdb
> OGR: OGROpen(/home/rshepard/data/grassdata/ODOT2014/hwynet_2015/) failed.
> FAILURE:
> /home/rshepard/data/grassdata/ODOT2014/hwynet_2015/' with the following
> drivers.
>    -> ESRI Shapefile
>    -> MapInfo File
> etc.
>    Will make a .tar.xz file of the source (that's about the smallest
> result) and send it off the list.
Try first with a directory ending with .gdb
> Thanks,
> Rich
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
http://www.spatialys.com
