[GRASS-user] Importing MrSID files
Rich Shepard rshepard at appl-ecosys.com
Tue Sep 20 11:43:07 PDT 2016
   A DRG file is in MrSID format with these files available: drg_s_or071.aux,
drg_s_or071.sid, drg_s_or071.sid.xml, drg_s_or071.sdw, and
drg_s_or071.sid.html.
   The accompanying .txt file tells me the projection is UTM Zone 10. To
create a new location for this map I need to specify the file holding the
projection information and select the correct format in the GUI's second
step.
   Which file should I use to inform the grass GIS of the MrSID projection?
Rich
