[GRASS-user] v.edit tool=merge
Markus Metz markus.metz.giswork at gmail.com
Fri Sep 23 06:00:50 PDT 2016
On Tue, Sep 20, 2016 at 3:06 PM, Vincent Bain <bain at toraval.fr> wrote:
> Hi,
> on a fresh (r69498) trunk version of grass, I have a problem running a
> v.edit command on a map.
> Given a vector map composed of 200 contour lines splitted in roughly
> 17000 line segments (adjacent nodes perfectly overlapping), I need to
> "unsplit" these contours. If I try to run the following command :
>         v.edit map=contours type=line tool=merge snap=vertex -r cats=0
> it looks line it never ends, i.e. the process does not return any error,
> RAM and CPU usages appear stable (not huge). After tens of minutes it
> still hangs up. I finally have to interrupt, then chucking out the
> topology-damaged map.
v.edit tool=merge hangs for zero-length lines. Such contours can occur
on peaks and in pits. Fixed in all G7 branches with r69556-8.
Markus M
> Running the same command on grass6.4 (after v.build the source map), it
> runs successfully within some minutes.
> Before I open a ticket, would anyone wish to give a try to my data ?
> Vincent.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
