[GRASS-user] Question on memory allocation and use
Rich Shepard
rshepard at appl-ecosys.com
Fri Sep 23 06:21:39 PDT 2016
On Fri, 23 Sep 2016, Markus Metz wrote:
> Apparently there are less than 52 MB of free memory left. The resulting
> vector contours must be quite large. Try to export GRASS_VECTOR_LOWMEM=1
> before running r.contour.
Markus,
I assumed that grass did not see the available memory, but did not realize
it would not use the available swap memory. I'll try exporting that
environment variable and re-run r.contour.
> Maybe also use a larger step or less levels.
The second time I almost doubled the step, but it still failed with an
out-of-memory error.
Thanks,
Rich
