[GRASS-user] Query Related to i.landsat8.swlst
    Blumentrath, Stefan
    Stefan.Blumentrath at nina.no
    Sat Sep 24 12:01:36 PDT 2016
Hei Eddison,
There was a question about i.landsat8.swlst on the GRASS user mailing list very recently:
https://lists.osgeo.org/pipermail/grass-user/2016-September/075134.html
Maybe the answer is useful for you too.
In general it is advisable to send such questions to the mailing list. There are more people who can answer or give you advise.
As for your specific question:
Yes, you can run i.landsat8.swlst only with band 10 and 11. Yet, you may be interested in excluding invalid pixels using the QA band (BQA). You can do that in i.landsat8.swlst or using the i.landsat8.qc addon (https://grass.osgeo.org/grass70/manuals/addons/i.landsat8.qc.html). In this case you would have to import band QBA too.
If you are concerned about data duplication, you can use r.external (https://grass.osgeo.org/grass70/manuals/r.external.html)  to just link the bands to your GRASS DB.
Cheers
Stefan
From: Eddison Araya [mailto:eddisonjose at gmail.com]
Sent: 24. september 2016 00:29
To: Blumentrath, Stefan <Stefan.Blumentrath at nina.no>
Subject: Query Related to i.landsat8.swlst
Estimado amigo, un gusto saludarte desde Costa Rica, deseo correr el proceso i.landsat8.swlst.
Lo primero que debo hacer es importar "todas" las bandas de la escena Landsat8? por ejemplo:
[Imágenes integradas 1]
En ese caso importo todas las bandas? o solo importo a GRASS la Banda 10 y 11?
Disculpe mi ignorancia, no uso GRASS pero necesito correr el proceso i.landsat8.swlst
Gracias
Eddison
Dear friend, nice to say hello from Costa Rica, i.landsat8.swlst want to run the process. The first thing I do is import "all" bands Landsat8 scene? for example: Integrated Pictures 1 In that case I import all the bands? or only imported into GRASS Band 10 and 11? Excuse my ignorance, but I need not use GRASS run the process i.landsat8.swlst thanks Eddison
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160924/faa35b8a/attachment-0001.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160924/faa35b8a/attachment-0001.png>
