[GRASS-user] Analyzing level ground
Rich Shepard rshepard at appl-ecosys.com
Mon Sep 26 19:00:26 PDT 2016
On Mon, 26 Sep 2016, Laurent C. wrote:
> Could you check that the point you want to set as outlet is inside your
> Region? Please check your Region extend.
> For the units, as long as the location is not in lat-long, Itzï will run.
> But it expects SI units, so using feet might gives you unexpected results.
> I would suggest to work with the units given in the manual.
Laurent,
   Yes, that point is well within the region. The region is set to the
analytical boundary which incorporates that point. That's what puzzled me
about the error message.
   I'll convert feet to meters and try again tomorrow morning.
Thanks,
Rich
