[GRASS-user] Analyzing level ground
    Laurent C.
    lrntct at gmail.com
    Mon Sep 26 18:11:07 PDT 2016
Hello Rich,
Could you check that the point you want to set as outlet is inside your
Region? Please check your Region extend.
For the units, as long as the location is not in lat-long, Itzï will run.
But it expects SI units, so using feet might gives you unexpected results.
I would suggest to work with the units given in the manual.
Regards,
Laurent
El sept. 26, 2016 18:31, "Rich Shepard" <rshepard at appl-ecosys.com> escribió:
> On Thu, 22 Sep 2016, Laurent C. wrote:
> If it is the case, you might give Itzï a try:
>> https://www.itzi.org/
> Laurent,
>   I'm emulating your tutorial with my data and have run into an error with
> r.water.outlet:
> r.water.outlet in=be_drainage out=watershed coord=753992.63435,57992.90515
> 9
> --overwrite
> WARNING: Ignoring point outside computation region: 753992.6343,57992.9052
>  100%
>   The coordinates are those of a culvert inflow (easting, northing) in
> international feet. Do I need to create a new location to convert these
> value to meters or have I done something else incorrectly?
> Regards,
> Rich
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160926/433c7813/attachment-0001.html>
