[GRASS-user] How can I rotate a raster map about a fixed axis
Qiao Cheng qiaoch at yeah.net
Mon Sep 26 21:02:14 PDT 2016
Dear Markus,
    Thanks for your suggestion! I will take a try.
Best regards
Cheng
At 2016-09-26 16:43:57, "Markus Neteler" <neteler at osgeo.org> wrote:
>On Mon, Sep 26, 2016 at 9:11 AM, Qiao Cheng <qiaoch at yeah.net> wrote:
>> Dear all,
>>     I have a simple artificial raster map created by r.mapcalc command, I
>> want rotating the raster map a finite angle about a fixed axis(for example,
>> the y axis). But I didn't know how to achieve this. Could you give me some
>> suggestions? Which command should I appeal to?
>There is an addon:
>i.rotate - Rotates the image around the centre of the computational window
>https://grass.osgeo.org/grass70/manuals/addons/i.rotate.html
>which you may want to try. Installation via graphical user interface
>or by directly using g.extension.
>Best,
>Markus
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160927/3bd80b1d/attachment.html>
