[GRASS-user] Fail to configure grass-7.0.4 under Ubuntu 16.04.1
JIA Pei
jp4work at gmail.com
Wed Sep 28 04:05:05 PDT 2016
By this command " sudo apt-get build-dep grass", I got:
The following NEW packages will be installed:
> autoconf2.13 libgdal-dev libgdal1i libhdf4-0-alt libhdf4-alt-dev
> liblas-c-dev liblas-c3 liblas-dev liblas3 netcdf-bin python-pil python-ply
> python-wxgtk3.0 python-wxversion
But, unfortunately,
1) installed my own libgdal-dev, instead of Ubuntu's default one from
repository
2) I NEVER use libhdf4, clearly I prefer libhdf5
3) I use Python 3.5.2, instead of python 2
4) liblas from repository requires libgdal-dev from repository, and relies
on libhdf4 ....
So, will grass move to
Python3
libhdf5
Cheers
On Tue, Sep 27, 2016 at 6:41 PM, Thomas Adams <tea3rd at gmail.com> wrote:
> Go here: https://grasswiki.osgeo.org/wiki/Compile_and_Install_Ubuntu
> Look at this:
> tar xzf grass-7.0.4.tar.gz
> cd grass-7.0.4/
> # install build dependency packages:
> # configure to taste..CFLAGS="-O2 -Wall" LDFLAGS="-s" ./configure \
> --enable-largefile=yes \
> --with-nls \
> --with-cxx \
> --with-proj-share=/usr/share/proj/ \
> --with-geos \
> --with-wxwidgets \
> --with-cairo \
> --with-opengl-libs=/usr/include/GL \
> --with-freetype=yes --with-freetype-includes="/usr/include/freetype2/" \
> --with-postgres=yes --with-postgres-includes="/usr/include/postgresql" \
> --with-sqlite=yes \
> --with-mysql=yes --with-mysql-includes="/usr/include/mysql" \
> --with-odbc=no \
> 2>&1 | tee config_log.txt
> # build using 4 CPU cores
> time make -j 4 2>&1 | tee build_log.txt
> sudo make install
> Tom
> On Tue, Sep 27, 2016 at 8:34 PM, JIA Pei <jp4work at gmail.com> wrote:
>> Hi, all:
>> I failed to configure grass-7.0.4, can anybody give me a hand?
>> OS: Ubuntu 16.04.1
>> GCC/G++: Ubuntu 5.4.0-6ubuntu1~16.04.2
>> FreeType: libfreetype6 2.6.1-0.1ubuntu2
>>> jiapei:grass-7.0.4$ ./configure
>>> checking host system type... x86_64-pc-linux-gnu
>>> checking for gcc... gcc
>>> checking whether the C compiler (gcc ) works... yes
>>> checking whether the C compiler (gcc ) is a cross-compiler... no
>>> checking whether we are using GNU C... yes
>>> checking whether gcc accepts -g... yes
>>> checking for Cygwin environment... no
>>> checking for mingw32 environment... no
>>> checking for executable suffix... no
>>> checking for full floating-point support... yes
>>> checking for pwd... /bin/pwd
>>> checking for source directory... /home/jiapei/Downloads/rsgis/O
>>> SGeo/grass/grass-7.0.4
>>> checking for build directory... /home/jiapei/Downloads/rsgis/O
>>> checking for svnversion... /usr/bin/svnversion
>>> checking for MacOSX App... no
>>> checking for MacOSX architectures... no
>>> checking for MacOSX SDK... no
>>> checking how to build libraries... shared
>>> checking for additional include dirs...
>>> checking for additional library dirs...
>>> checking for a BSD compatible install... /usr/bin/install -c
>>> checking for flex... flex
>>> checking for yywrap in -lfl... yes
>>> checking for bison... bison -y
>>> checking for ranlib... ranlib
>>> checking for ar... ar
>>> checking for env... env
>>> checking for perl... /usr/bin/perl
>>> checking how to run the C preprocessor... gcc -E
>>> checking for ANSI C header files... yes
>>> checking for limits.h... yes
>>> checking for termio.h... yes
>>> checking for termios.h... yes
>>> checking for unistd.h... yes
>>> checking for values.h... yes
>>> checking for f2c.h... yes
>>> checking for g2c.h... no
>>> checking for sys/ioctl.h... yes
>>> checking for sys/mtio.h... yes
>>> checking for sys/resource.h... yes
>>> checking for sys/time.h... yes
>>> checking for sys/timeb.h... yes
>>> checking for sys/types.h... yes
>>> checking for sys/utsname.h... yes
>>> checking for libintl.h... yes
>>> checking for iconv.h... yes
>>> checking for langinfo.h... yes
>>> checking whether time.h and sys/time.h may both be included... yes
>>> checking for off_t... yes
>>> checking for uid_t in sys/types.h... yes
>>> checking return type of signal handlers... void
>>> checking for ftime... yes
>>> checking for gethostname... yes
>>> checking for gettimeofday... yes
>>> checking for lseek... yes
>>> checking for nice... yes
>>> checking for time... yes
>>> checking for uname... yes
>>> checking for seteuid... yes
>>> checking for setpriority... yes
>>> checking for setreuid... yes
>>> checking for setruid... no
>>> checking for drand48... yes
>>> checking for putenv... yes
>>> checking for setenv... yes
>>> checking for nanosleep... yes
>>> checking whether setpgrp takes no argument... yes
>>> checking for long long int... yes
>>> checking for W11... no
>>> checking for X... libraries , headers
>>> checking for dnet_ntoa in -ldnet... yes
>>> checking for gethostbyname... yes
>>> checking for connect... yes
>>> checking for remove... yes
>>> checking for shmat... yes
>>> checking for IceConnectionNumber in -lICE... yes
>>> checking for library containing cuserid... none required
>>> checking for asprintf... yes
>>> checking for atan... no
>>> checking for atan in -lm... yes
>>> checking for dlsym... no
>>> checking for dlsym in -ldl... yes
>>> checking for iconv... yes
>>> checking for socket... yes
>>> checking for location of zlib includes...
>>> checking for zlib.h... yes
>>> checking for location of zlib library...
>>> checking for deflate in -lz... yes
>>> checking for location of External PROJ.4 includes...
>>> checking for proj_api.h... yes
>>> checking External PROJ.4 version... 492
>>> checking for location of External PROJ.4 library...
>>> checking for pj_get_def in -lproj... yes
>>> checking for location of External PROJ.4 data files...
>>> configure: warning: *** External PROJ.4 directory not specified; default
>>> will be used
>>> checking for /usr/share/proj/epsg... yes
>>> checking for nad2bin... /usr/bin/nad2bin
>>> checking whether to use regex... yes
>>> checking for location of regex includes...
>>> checking for regex.h... yes
>>> checking for location of regex library...
>>> checking for regcomp... yes
>>> checking whether to use Readline... no
>>> checking whether to use GDAL... yes
>>> checking for gdal-config... /usr/local/bin/gdal-config
>>> checking whether to use libLAS... no
>>> checking whether to use NetCDF... no
>>> checking whether to use GEOS... no
>>> checking whether to use TIFF... yes
>>> checking for location of TIFF includes...
>>> checking for tiffio.h... yes
>>> checking for location of TIFF library...
>>> checking for TIFFOpen in -ltiff... yes
>>> checking whether to use PNG... yes
>>> checking for location of PNG includes...
>>> checking for png.h... yes
>>> checking for location of PNG library...
>>> checking for png_read_image in -lpng... yes
>>> checking whether to use PostgreSQL... no
>>> checking whether to use MySQL... no
>>> checking whether to use SQLite... yes
>>> checking for location of SQLite includes...
>>> checking for sqlite3.h... yes
>>> checking for location of SQLite library...
>>> checking for sqlite3_open in -lsqlite3... yes
>>> checking whether to use OpenGL... yes
>>> checking for location of OpenGL includes...
>>> checking for GL/gl.h... yes
>>> checking for GL/glu.h... yes
>>> checking for location of OpenGL library...
>>> checking for glBegin in -lGL... yes
>>> checking for gluBeginCurve in -lGLU... yes
>>> checking for glXCreatePbuffer... yes
>>> checking for glXCreateGLXPixmap... yes
>>> checking whether to use ODBC... no
>>> checking whether to use FFTW... yes
>>> checking for location of FFTW includes...
>>> checking for fftw3.h... yes
>>> checking for location of FFTW library...
>>> checking for fftw_execute in -lfftw3... yes
>>> checking whether to use BLAS... no
>>> checking whether to use LAPACK... no
>>> checking whether to use Cairo... yes
>>> checking for location of cairo includes...
>>> checking for cairo.h... yes
>>> checking for location of cairo library...
>>> checking for cairo linking flags...
>>> checking for cairo_create... yes
>>> checking for cairo_xlib_surface_create_with_xrender_format... yes
>>> checking for cairo_xlib_surface_get_xrender_format... yes
>>> checking whether to use FreeType... yes
>>> checking for location of FreeType includes...
>>> *checking for ft2build.h... no **configure: error: *** Unable to locate
>>> FreeType includes.*
>>> jiapei:grass-7.0.4$
>> Cheers
>> Pei JIA, Ph.D.
>> Email: jp4work at gmail.com
>> cell in Canada: +1 778-863-5816
>> cell in China: +86 186-8244-3503
>> Welcome to Vision Open
>> http://www.visionopen.com
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
Pei JIA, Ph.D.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160928/ef0d1faf/attachment-0001.html>
