[GRASS-user] Fail to configure grass-7.0.4 under Ubuntu 16.04.1
    Thomas Adams
    tea3rd at gmail.com
    Tue Sep 27 18:41:23 PDT 2016
Go here: https://grasswiki.osgeo.org/wiki/Compile_and_Install_Ubuntu
Look at this:
 tar xzf grass-7.0.4.tar.gz
 cd grass-7.0.4/
 # install build dependency packages:
 sudo apt-get build-dep grass
 # configure to taste..CFLAGS="-O2 -Wall" LDFLAGS="-s" ./configure \
    --enable-largefile=yes \
    --with-nls \
    --with-cxx \
    --with-proj-share=/usr/share/proj/ \
    --with-geos \
    --with-wxwidgets \
    --with-cairo \
    --with-opengl-libs=/usr/include/GL \
    --with-freetype=yes --with-freetype-includes="/usr/include/freetype2/" \
    --with-postgres=yes --with-postgres-includes="/usr/include/postgresql" \
    --with-sqlite=yes \
    --with-mysql=yes --with-mysql-includes="/usr/include/mysql" \
    --with-odbc=no \
     2>&1 | tee config_log.txt
 # build using 4 CPU cores
 time make -j 4 2>&1 | tee build_log.txt
 sudo make install
Tom
On Tue, Sep 27, 2016 at 8:34 PM, JIA Pei <jp4work at gmail.com> wrote:
> Hi, all:
> I failed to configure grass-7.0.4, can anybody give me a hand?
> OS: Ubuntu 16.04.1
> GCC/G++: Ubuntu 5.4.0-6ubuntu1~16.04.2
> FreeType: libfreetype6 2.6.1-0.1ubuntu2
>> jiapei:grass-7.0.4$ ./configure
>> checking host system type... x86_64-pc-linux-gnu
>> checking for gcc... gcc
>> checking whether the C compiler (gcc  ) works... yes
>> checking whether the C compiler (gcc  ) is a cross-compiler... no
>> checking whether we are using GNU C... yes
>> checking whether gcc accepts -g... yes
>> checking for Cygwin environment... no
>> checking for mingw32 environment... no
>> checking for executable suffix... no
>> checking for full floating-point support... yes
>> checking for pwd... /bin/pwd
>> checking for source directory... /home/jiapei/Downloads/rsgis/
>> OSGeo/grass/grass-7.0.4
>> checking for build directory... /home/jiapei/Downloads/rsgis/
>> checking for svnversion... /usr/bin/svnversion
>> checking for MacOSX App... no
>> checking for MacOSX architectures... no
>> checking for MacOSX SDK... no
>> checking how to build libraries... shared
>> checking for additional include dirs...
>> checking for additional library dirs...
>> checking for a BSD compatible install... /usr/bin/install -c
>> checking for flex... flex
>> checking for yywrap in -lfl... yes
>> checking for bison... bison -y
>> checking for ranlib... ranlib
>> checking for ar... ar
>> checking for env... env
>> checking for perl... /usr/bin/perl
>> checking how to run the C preprocessor... gcc -E
>> checking for ANSI C header files... yes
>> checking for limits.h... yes
>> checking for termio.h... yes
>> checking for termios.h... yes
>> checking for unistd.h... yes
>> checking for values.h... yes
>> checking for f2c.h... yes
>> checking for g2c.h... no
>> checking for sys/ioctl.h... yes
>> checking for sys/mtio.h... yes
>> checking for sys/resource.h... yes
>> checking for sys/time.h... yes
>> checking for sys/timeb.h... yes
>> checking for sys/types.h... yes
>> checking for sys/utsname.h... yes
>> checking for libintl.h... yes
>> checking for iconv.h... yes
>> checking for langinfo.h... yes
>> checking whether time.h and sys/time.h may both be included... yes
>> checking for off_t... yes
>> checking for uid_t in sys/types.h... yes
>> checking return type of signal handlers... void
>> checking for ftime... yes
>> checking for gethostname... yes
>> checking for gettimeofday... yes
>> checking for lseek... yes
>> checking for nice... yes
>> checking for time... yes
>> checking for uname... yes
>> checking for seteuid... yes
>> checking for setpriority... yes
>> checking for setreuid... yes
>> checking for setruid... no
>> checking for drand48... yes
>> checking for putenv... yes
>> checking for setenv... yes
>> checking for nanosleep... yes
>> checking whether setpgrp takes no argument... yes
>> checking for long long int... yes
>> checking for W11... no
>> checking for X... libraries , headers
>> checking for dnet_ntoa in -ldnet... yes
>> checking for gethostbyname... yes
>> checking for connect... yes
>> checking for remove... yes
>> checking for shmat... yes
>> checking for IceConnectionNumber in -lICE... yes
>> checking for library containing cuserid... none required
>> checking for asprintf... yes
>> checking for atan... no
>> checking for atan in -lm... yes
>> checking for dlsym... no
>> checking for dlsym in -ldl... yes
>> checking for iconv... yes
>> checking for socket... yes
>> checking for location of zlib includes...
>> checking for zlib.h... yes
>> checking for location of zlib library...
>> checking for deflate in -lz... yes
>> checking for location of External PROJ.4 includes...
>> checking for proj_api.h... yes
>> checking External PROJ.4 version... 492
>> checking for location of External PROJ.4 library...
>> checking for pj_get_def in -lproj... yes
>> checking for location of External PROJ.4 data files...
>> configure: warning: *** External PROJ.4 directory not specified; default
>> will be used
>> checking for /usr/share/proj/epsg... yes
>> checking for nad2bin... /usr/bin/nad2bin
>> checking whether to use regex... yes
>> checking for location of regex includes...
>> checking for regex.h... yes
>> checking for location of regex library...
>> checking for regcomp... yes
>> checking whether to use Readline... no
>> checking whether to use GDAL... yes
>> checking for gdal-config... /usr/local/bin/gdal-config
>> checking whether to use libLAS... no
>> checking whether to use NetCDF... no
>> checking whether to use GEOS... no
>> checking whether to use TIFF... yes
>> checking for location of TIFF includes...
>> checking for tiffio.h... yes
>> checking for location of TIFF library...
>> checking for TIFFOpen in -ltiff... yes
>> checking whether to use PNG... yes
>> checking for location of PNG includes...
>> checking for png.h... yes
>> checking for location of PNG library...
>> checking for png_read_image in -lpng... yes
>> checking whether to use PostgreSQL... no
>> checking whether to use MySQL... no
>> checking whether to use SQLite... yes
>> checking for location of SQLite includes...
>> checking for sqlite3.h... yes
>> checking for location of SQLite library...
>> checking for sqlite3_open in -lsqlite3... yes
>> checking whether to use OpenGL... yes
>> checking for location of OpenGL includes...
>> checking for GL/gl.h... yes
>> checking for GL/glu.h... yes
>> checking for location of OpenGL library...
>> checking for glBegin in -lGL... yes
>> checking for gluBeginCurve in -lGLU... yes
>> checking for glXCreatePbuffer... yes
>> checking for glXCreateGLXPixmap... yes
>> checking whether to use ODBC... no
>> checking whether to use FFTW... yes
>> checking for location of FFTW includes...
>> checking for fftw3.h... yes
>> checking for location of FFTW library...
>> checking for fftw_execute in -lfftw3... yes
>> checking whether to use BLAS... no
>> checking whether to use LAPACK... no
>> checking whether to use Cairo... yes
>> checking for location of cairo includes...
>> checking for cairo.h... yes
>> checking for location of cairo library...
>> checking for cairo linking flags...
>> checking for cairo_create... yes
>> checking for cairo_xlib_surface_create_with_xrender_format... yes
>> checking for cairo_xlib_surface_get_xrender_format... yes
>> checking whether to use FreeType... yes
>> checking for location of FreeType includes...
>> *checking for ft2build.h... no **configure: error: *** Unable to locate
>> FreeType includes.*
>> jiapei:grass-7.0.4$
> Cheers
> Pei JIA, Ph.D.
> Email: jp4work at gmail.com
> cell in Canada:    +1 778-863-5816
> cell in China: +86 186-8244-3503
> Welcome to Vision Open
> http://www.visionopen.com
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160927/f598e1d4/attachment-0001.html>
