[GRASS-user] Fail to configure grass-7.0.4 under Ubuntu 16.04.1
    JIA Pei
    jp4work at gmail.com
    Tue Sep 27 17:34:43 PDT 2016
Hi, all:
I failed to configure grass-7.0.4, can anybody give me a hand?
OS: Ubuntu 16.04.1
GCC/G++: Ubuntu 5.4.0-6ubuntu1~16.04.2
FreeType: libfreetype6 2.6.1-0.1ubuntu2
> jiapei:grass-7.0.4$ ./configure
> checking host system type... x86_64-pc-linux-gnu
> checking for gcc... gcc
> checking whether the C compiler (gcc  ) works... yes
> checking whether the C compiler (gcc  ) is a cross-compiler... no
> checking whether we are using GNU C... yes
> checking whether gcc accepts -g... yes
> checking for Cygwin environment... no
> checking for mingw32 environment... no
> checking for executable suffix... no
> checking for full floating-point support... yes
> checking for pwd... /bin/pwd
> checking for source directory...
> /home/jiapei/Downloads/rsgis/OSGeo/grass/grass-7.0.4
> checking for build directory...
> checking for svnversion... /usr/bin/svnversion
> checking for MacOSX App... no
> checking for MacOSX architectures... no
> checking for MacOSX SDK... no
> checking how to build libraries... shared
> checking for additional include dirs...
> checking for additional library dirs...
> checking for a BSD compatible install... /usr/bin/install -c
> checking for flex... flex
> checking for yywrap in -lfl... yes
> checking for bison... bison -y
> checking for ranlib... ranlib
> checking for ar... ar
> checking for env... env
> checking for perl... /usr/bin/perl
> checking how to run the C preprocessor... gcc -E
> checking for ANSI C header files... yes
> checking for limits.h... yes
> checking for termio.h... yes
> checking for termios.h... yes
> checking for unistd.h... yes
> checking for values.h... yes
> checking for f2c.h... yes
> checking for g2c.h... no
> checking for sys/ioctl.h... yes
> checking for sys/mtio.h... yes
> checking for sys/resource.h... yes
> checking for sys/time.h... yes
> checking for sys/timeb.h... yes
> checking for sys/types.h... yes
> checking for sys/utsname.h... yes
> checking for libintl.h... yes
> checking for iconv.h... yes
> checking for langinfo.h... yes
> checking whether time.h and sys/time.h may both be included... yes
> checking for off_t... yes
> checking for uid_t in sys/types.h... yes
> checking return type of signal handlers... void
> checking for ftime... yes
> checking for gethostname... yes
> checking for gettimeofday... yes
> checking for lseek... yes
> checking for nice... yes
> checking for time... yes
> checking for uname... yes
> checking for seteuid... yes
> checking for setpriority... yes
> checking for setreuid... yes
> checking for setruid... no
> checking for drand48... yes
> checking for putenv... yes
> checking for setenv... yes
> checking for nanosleep... yes
> checking whether setpgrp takes no argument... yes
> checking for long long int... yes
> checking for W11... no
> checking for X... libraries , headers
> checking for dnet_ntoa in -ldnet... yes
> checking for gethostbyname... yes
> checking for connect... yes
> checking for remove... yes
> checking for shmat... yes
> checking for IceConnectionNumber in -lICE... yes
> checking for library containing cuserid... none required
> checking for asprintf... yes
> checking for atan... no
> checking for atan in -lm... yes
> checking for dlsym... no
> checking for dlsym in -ldl... yes
> checking for iconv... yes
> checking for socket... yes
> checking for location of zlib includes...
> checking for zlib.h... yes
> checking for location of zlib library...
> checking for deflate in -lz... yes
> checking for location of External PROJ.4 includes...
> checking for proj_api.h... yes
> checking External PROJ.4 version... 492
> checking for location of External PROJ.4 library...
> checking for pj_get_def in -lproj... yes
> checking for location of External PROJ.4 data files...
> configure: warning: *** External PROJ.4 directory not specified; default
> will be used
> checking for /usr/share/proj/epsg... yes
> checking for nad2bin... /usr/bin/nad2bin
> checking whether to use regex... yes
> checking for location of regex includes...
> checking for regex.h... yes
> checking for location of regex library...
> checking for regcomp... yes
> checking whether to use Readline... no
> checking whether to use GDAL... yes
> checking for gdal-config... /usr/local/bin/gdal-config
> checking whether to use libLAS... no
> checking whether to use NetCDF... no
> checking whether to use GEOS... no
> checking whether to use TIFF... yes
> checking for location of TIFF includes...
> checking for tiffio.h... yes
> checking for location of TIFF library...
> checking for TIFFOpen in -ltiff... yes
> checking whether to use PNG... yes
> checking for location of PNG includes...
> checking for png.h... yes
> checking for location of PNG library...
> checking for png_read_image in -lpng... yes
> checking whether to use PostgreSQL... no
> checking whether to use MySQL... no
> checking whether to use SQLite... yes
> checking for location of SQLite includes...
> checking for sqlite3.h... yes
> checking for location of SQLite library...
> checking for sqlite3_open in -lsqlite3... yes
> checking whether to use OpenGL... yes
> checking for location of OpenGL includes...
> checking for GL/gl.h... yes
> checking for GL/glu.h... yes
> checking for location of OpenGL library...
> checking for glBegin in -lGL... yes
> checking for gluBeginCurve in -lGLU... yes
> checking for glXCreatePbuffer... yes
> checking for glXCreateGLXPixmap... yes
> checking whether to use ODBC... no
> checking whether to use FFTW... yes
> checking for location of FFTW includes...
> checking for fftw3.h... yes
> checking for location of FFTW library...
> checking for fftw_execute in -lfftw3... yes
> checking whether to use BLAS... no
> checking whether to use LAPACK... no
> checking whether to use Cairo... yes
> checking for location of cairo includes...
> checking for cairo.h... yes
> checking for location of cairo library...
> checking for cairo linking flags...
> checking for cairo_create... yes
> checking for cairo_xlib_surface_create_with_xrender_format... yes
> checking for cairo_xlib_surface_get_xrender_format... yes
> checking whether to use FreeType... yes
> checking for location of FreeType includes...
> *checking for ft2build.h... no **configure: error: *** Unable to locate
> FreeType includes.*
> jiapei:grass-7.0.4$
Cheers
Pei JIA, Ph.D.
Email: jp4work at gmail.com
cell in Canada:    +1 778-863-5816
cell in China: +86 186-8244-3503
Welcome to Vision Open
http://www.visionopen.com
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160927/7a19d5ec/attachment-0001.html>
