[GRASS-user] 7.3.svn observations
Robert Kuszinger kuszinger at giscom.hu
Wed Sep 28 23:51:05 PDT 2016
Hello!
The same happens in d.vect.legend in a slightly different manner but along
the same logic. I added a workaround tip for example in m.printws
documentation, and yes, now d.text could be affected and many others with
text entry or auto temp file generating.
I wonder what the outcome would be. GRASS users with practice could handle
this but newcomers could be depressed.
I only wanted to say that is important in my opinion as well.
R
2016-09-28 15:49 GMT+02:00 Anna Petrášová <kratochanna at gmail.com>:
> Hi Rich,
> I can see what's the problem now. You typed text in the d.text window
> which automatically creates a temporary file with that text. Path to
> that temp file is saved in the gxw file,but then the files are
> deleted. I don't have currently a good way to fix this. You have to
> save it into a regular file. Please open a ticket for this.
> Anna
> On Wed, Sep 28, 2016 at 9:38 AM, Rich Shepard <rshepard at appl-ecosys.com>
> wrote:
> > On Tue, 27 Sep 2016, Anna Petrášová wrote:
> >> Hmm, the text annotations should be saved too in 7.2. Could you look in
> >> the gxw xml file, there should be some 'd.text' in there.
> > Anna,
> >   I'm replying off the mail list because the attachments have proprietary
> > client data.
> >   The .gxw file has d.text sections but the name values are numbers and
> not
> > the text I entered. This file is attached.
> >   The two images are of the correctly annotated map and the .gxw-loaded
> map
> > (with layer sequence not current).
> >   I'll try this again with 7.2 and report the results to the mail list.
> > Thanks,
> > Rich
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160929/526ec55d/attachment.html>
