[GRASS-user] 7.3.svn observations
Anna Petrášová
kratochanna at gmail.com
Wed Sep 28 06:49:47 PDT 2016
Hi Rich,
I can see what's the problem now. You typed text in the d.text window
which automatically creates a temporary file with that text. Path to
that temp file is saved in the gxw file,but then the files are
deleted. I don't have currently a good way to fix this. You have to
save it into a regular file. Please open a ticket for this.
Anna
On Wed, Sep 28, 2016 at 9:38 AM, Rich Shepard <rshepard at appl-ecosys.com> wrote:
> On Tue, 27 Sep 2016, Anna Petrášová wrote:
>> Hmm, the text annotations should be saved too in 7.2. Could you look in
>> the gxw xml file, there should be some 'd.text' in there.
> Anna,
> I'm replying off the mail list because the attachments have proprietary
> client data.
> The .gxw file has d.text sections but the name values are numbers and not
> the text I entered. This file is attached.
> The two images are of the correctly annotated map and the .gxw-loaded map
> (with layer sequence not current).
> I'll try this again with 7.2 and report the results to the mail list.
> Thanks,
> Rich
