[GRASS-user] 7.3.svn observations
    Anna Petrášová
    kratochanna at gmail.com
    Tue Sep 27 20:30:17 PDT 2016
On Tue, Sep 27, 2016 at 4:28 PM, Rich Shepard <rshepard at appl-ecosys.com> wrote:
> For information; response not necessary:
>   Prepared a map in the map display window with annotations: scale bar/north
> arrow and text. The map was saved as a .png and the workspace with the
> raster and vector maps was also saved. When I again invoked grass and loaded
> the saved workspace the text annotations were gone while the scale bar/north
> arrow were present. Perhaps whoever contributes to the map annotation
> function(s) and add text retention and display when workspaces are saved and
> loaded.
Hmm, the text annotations should be saved too in 7.2. Could you look
in the gxw xml file, there should be some 'd.text' in there.
Anna
>   Also, while a GTK+ issue rather than a GRASS issue, there are multiple
> pango errors thrown ("(wxgui.py:12046): Pango-CRITICAL **:
> pango_layout_get_cursor_pos: assertion ndex >= 0 && index <= layout->length'
> failed") and I'm assuming these appeared when I added text to the map.
> Thanks all,
> Rich
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
