[GRASS-user] 'Maximum vector line maps loaded'
Alec Ventura
alecventura at hotmail.com
Fri Sep 30 05:21:28 PDT 2016
Yeah, I notice that changes on v.patch, but I kind aprehensive to download 7.2 version because the download link was with a line through it, like it was deprecated or something =P.
I will try 7.3 that is in development.
Tnks.
Alec
De: Vaclav Petras <wenzeslaus at gmail.com>
Enviado: quinta-feira, 29 de setembro de 2016 22:30
Para: Alec Ventura
Cc: grass-user at lists.osgeo.org
Assunto: Re: [GRASS-user] 'Maximum vector line maps loaded'
On Thu, Sep 29, 2016 at 9:08 PM, Alec Ventura <alecventura at hotmail.com<mailto:alecventura at hotmail.com>> wrote:
But the v.path layer dont support 3d.
At least in 7.2, v.patch supports merging 3D points. In some cases you may need to provide some extra flags, but in general Z should work.
https://grass.osgeo.org/grass72/manuals/v.patch.html
https://trac.osgeo.org/grass/ticket/2433
I need some help to: or increase the MAX_VECTS variable value,
That must be done in the source code (it is not expected you add tens of vectors to 3D view, you can open enhancement ticket). If you compile GRASS on Linux, you could theoretically increase it.
or some other command like v.patch to unify all my boreholes.
Well, you could always work around it by exporting points using v.out.ascii merging the files (e.g. with cat on Linux) and then importing them back with v.in.ascii. But that's a workaround, v.patch should work.
Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160930/d3c64a3c/attachment.html>
