[GRASS-user] GRASS Environment Variables
Andres Solarte
e.andres.solartec at gmail.com
Wed Apr 5 05:50:50 PDT 2017
Hello Joseph,
my fault,
add this line after #3.
#3. Call function (examples)
import grass.script as gscript
now it should works!
remember set your coordinates and resolution (example)
res = 0.008626704385179
n = 14.
s = -2.
w = -76
e = -65
Regards
2017-04-05 9:43 GMT-03:00 Joseph Kariuki <joehene at gmail.com>:
> Hi Andres, I have run the code in pycharm but still raises an error
> /usr/bin/python2.7 /home/hempire/PycharmProjects/GRASS/ingrass.py
>> Traceback (most recent call last):
>> File "/home/hempire/PycharmProjects/GRASS/ingrass.py", line 43, in
>> <module>
>> gscript.run_command('g.region', n=float(n), s=float(s), e=float(e),
>> w=float(w), ewres=float(res), nsres=float(res))
>> NameError: name 'gscript' is not defined
>> Process finished with exit code 1
> However on terminal it executes with no errors. I will stick to using
> terminal. PyCharm is limiting.
> Kind Regards,
> *Joseph Kariuki*
> *Geospatial Engineer** | **GIS / Web Developer*
> On Wed, Apr 5, 2017 at 2:12 AM, Andres Solarte <
> e.andres.solartec at gmail.com> wrote:
>> Hello Joseph,
>> This is the way I work with grass from python:
>> #!/usr/bin/env python
>> # -*- coding: utf-8 -*-
>> import os
>> import sys
>> #1. Define function
>> def conectar(location,mapset):
>> # path to the GRASS GIS launch script
>> grass7bin = '/usr/bin/grass72'
>> # Set GISDBASE environment variable
>> gisdb = "/media/andres/Andres/TesisGrass"
>> os.environ['GISDBASE'] = gisdb
>> # query GRASS 7 itself for its GISBASE
>> gisbase = "/usr/lib/grass72"
>> os.environ['GISBASE'] = gisbase
>> # define GRASS-Python environment
>> gpydir = "/usr/lib/grass72/etc/python"
>> sys.path.append(gpydir)
>> # import GRASS Python bindings
>> import grass.script.setup as gsetup
>> ############ launch session
>> gsetup.init(gisbase, gisdb, location, mapset)
>> #2. Now you can connect with your projects
>> location = "your location"
>> mapset = "your mapset"
>> gscript.run_command("r.in.gdal", input="/home/..../image.tif",
>> flags='e',output = "image")
>> 2017-04-04 11:12 GMT-03:00 Joseph Kariuki <joehene at gmail.com>:
>>> Hi?
>>> I have been trying to call GRASS modules using python outside GRASS
>>> session, I am coding in PyCharm however, I am having a problem importing
>>> grass scripts and the solution being provided is setting GRASS environment
>>> variables. How do I go about that so to import GRASS modules in Pycharm?
>>> Kind Regards,
>>> *Joseph Kariuki*
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170405/552127cd/attachment-0001.html>
