[GRASS-user] GRASS Environment Variables
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Wed Apr 5 05:47:01 PDT 2017
Hi Joseph,
You just have to import the module:
import grass.script as gscript
See also:
https://grass.osgeo.org/grass72/manuals/libpython/script_intro.html
Cheers
Stefan
From: grass-user [mailto:grass-user-bounces at lists.osgeo.org] On Behalf Of Joseph Kariuki
Sent: onsdag 5. april 2017 14.43
To: Andres Solarte <e.andres.solartec at gmail.com>
Cc: GRASS user list <grass-user at lists.osgeo.org>
Subject: Re: [GRASS-user] GRASS Environment Variables
Hi Andres, I have run the code in pycharm but still raises an error
/usr/bin/python2.7 /home/hempire/PycharmProjects/GRASS/ingrass.py
File "/home/hempire/PycharmProjects/GRASS/ingrass.py", line 43, in <module>
gscript.run_command('g.region', n=float(n), s=float(s), e=float(e), w=float(w), ewres=float(res), nsres=float(res))
NameError: name 'gscript' is not defined
Process finished with exit code 1
However on terminal it executes with no errors. I will stick to using terminal. PyCharm is limiting.
Kind Regards,
Joseph Kariuki
Geospatial Engineer | GIS / Web Developer
On Wed, Apr 5, 2017 at 2:12 AM, Andres Solarte <e.andres.solartec at gmail.com<mailto:e.andres.solartec at gmail.com>> wrote:
Hello Joseph,
This is the way I work with grass from python:
#!/usr/bin/env python
# -*- coding: utf-8 -*-
import os
import sys
#1. Define function
def conectar(location,mapset):
# path to the GRASS GIS launch script
grass7bin = '/usr/bin/grass72'
# Set GISDBASE environment variable
gisdb = "/media/andres/Andres/TesisGrass"
os.environ['GISDBASE'] = gisdb
# query GRASS 7 itself for its GISBASE
gisbase = "/usr/lib/grass72"
os.environ['GISBASE'] = gisbase
# define GRASS-Python environment
gpydir = "/usr/lib/grass72/etc/python"
sys.path.append(gpydir)
# import GRASS Python bindings
import grass.script.setup as gsetup
############ launch session
gsetup.init(gisbase, gisdb, location, mapset)
#2. Now you can connect with your projects
location = "your location"
mapset = "your mapset"
#3. Call function (examples)
gscript.run_command("r.in<http://r.in>.gdal", input="/home/..../image.tif", flags='e',output = "image")
2017-04-04 11:12 GMT-03:00 Joseph Kariuki <joehene at gmail.com<mailto:joehene at gmail.com>>:
Hi?
I have been trying to call GRASS modules using python outside GRASS session, I am coding in PyCharm however, I am having a problem importing grass scripts and the solution being provided is setting GRASS environment variables. How do I go about that so to import GRASS modules in Pycharm?
Kind Regards,
Joseph Kariuki
grass-user mailing list
grass-user at lists.osgeo.org<mailto:grass-user at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170405/4862c121/attachment-0001.html>
