[GRASS-user] r.mask: no MASK created when using many categories
Mira Kattwinkel kattwinkel-mira at uni-landau.de
Wed Apr 5 06:59:43 PDT 2017
Dear Micha
thanks for your suggestion.
Actually, that's is what I usually do. However, I am not really
interested in the catchment of the endpoints of the edges but in
sampling points lying at the streams. If a point lies within the dem
cell of the outlet, which can be a confluence of two streams, the
coordinate approach will result in the catchment of both confluences,
although the point lies just at one of them. That's why I came up with
the idea of summing up the subcatchments of only the relevant branch of
the stream network.
Maybe there are other thoughts on that?
Mira
On 05/04/17 15:25, Micha Silver wrote:
> On 04/05/2017 03:22 PM, Mira Kattwinkel wrote:
>> Dear List,
>> I am using r.mask to create a new raster map that only contains
>> certain categories given in 'maskcats'. Then, I use r.mapcalc to save
>> the map under a new name and (to be on the save side) delete the MASK
>> with r.mask flag '-r'. I do this in a loop and it works fine until a
>> case when the number of categories to combine is 213 (trail and error
>> lead to 106 as the maximum number that works fine). Flag 'verbose'
>> gives the message that a MASK was created, but none is there. The
>> problem arises in both cases when I directly use Grass or through R
>> using execGrass.
>> Is there a limit in the number of categories that can be passed to
>> r.mask? I did not find any hint about that. Additionally, I wonder
>> why there is no error message but in the contrary one that tells me
>> that a MASK was created even when it failed.
>> In case the details are important (or if anybody has a better idea
>> how to achieve what I want): I have a raster map of subcatchemts
>> belonging to stream segments created with r.stream.basins. For the
>> endpoints of segments, I want to combine these subcatchments to a
>> total catchment raster map containing all upstream catchments.
> If you have the endpoint of of the outlet segment, you might use that
> as the "coordinates" parameter to r.stream.basins to create a single
> large drainage basin. Then use that as the mask to get out the
> subcatchments.
>> Thanks a lot,
>> Mira
> Micha Silver
> cell: +972-523-665918
Dr. Mira Kattwinkel
Quantitative Landscape Ecology
Institute for Environmental Sciences
University of Koblenz-Landau
Fortstraße 7
76829 Landau
Germany
Phone: + 49 6341 280-31553
Office: Building I, Room 2.02
