[GRASS-user] r.import extent=region ignored
Tomáš Brunclík brunclik at atlas.cz
Thu Apr 6 11:51:49 PDT 2017
Hello,
Using GRASS 7.2.1svn r70842 (Linux 64bit from today's binary snapshot)
and it seems the extent=region parameter of the r.import is just
ignored. Tried from GUI, then from command line, first with multi band
virtual raster, then with single JPEG2000 file (as in the example
below), with and without the -n option. Is it a known bug, or does it
work for someone, perhaps in some other version, or with other input
formats? I tried to look in trac, but did not see anything. I am aware
how I can clip the rasters after import, but it seemed one of the fine
new features which would make the daily use a little more comfortable...
Tomas Brunclik
GRASS 7.2.1svn (utm33n):~ > r.import -o
input=/home/tom/GISdata/DPZ/Chlorofyl-vzorkovani/2016-09-13_R122_S2A_samping_09-13/S2A_USER_PRD_MSIL2A_PDMC_20160915T151344_R122_V20160913T100022_20160913T100504.SAFE/GRANULE/S2A_USER_MSI_L2A_TL_SGS__20160913T170505_A006411_T33UWR_N02.04/IMG_DATA/R20m/S2A_USER_MSI_L2A_TL_SGS__20160913T170505_A006411_T33UWR_B04_20m.jp2
output=20160913_R122.3b extent=region
UPOZORNĚNÍ: Přeskakuje se kontrola kartografického zobrazení.
Proceeding with import of 1 raster bands...
Importing raster map <20160913_R122.3b>...
  100%
GRASS 7.2.1svn (utm33n):~ > g.region -p
projection: 1 (UTM)
zone:       33
datum:      wgs84
ellipsoid:  a=6378137 es=0.00669438
north:      5569000
south:      5543320
west:       531260
east:       570320
nsres:      20
ewres:      20
rows:       1284
cols:       1953
cells:      2507652
GRASS 7.2.1svn (utm33n):~ > r.info map=20160913_R122.3b
  | Map:      20160913_R122.3b               Date: Thu Apr  6 20:27:43
2017    |
  | Mapset:   sentinel2test                  Login of Creator:
tom             |
  | DataBase: /home/tom/GISdata/grass |
  | Title: |
  | Timestamp: none |
  |   Type of Map:  raster               Number of Categories:
0               |
  |   Data Type:
CELL                                                       |
  |   Rows: 5490                                                       |
  |   Columns: 5490                                                       |
  |   Total Cells:
30140100                                                   |
  |        Projection: UTM (zone
33)                                           |
  |            N:    5600040    S:    5490240   Res:
20                     |
  |            E:     609780    W:     499980   Res:
20                     |
  |   Range of data:    min = 1  max =
17010                                   |
  |   Data Description: |
  |    generated by
r.in.gdal                                                  |
  | Comments: |
  |    r.in.gdal -o -k
input="/home/tom/GISdata/DPZ/Chlorofyl-vzorkovani/20\   |
  | 16-09-13_R122_S2A_samping_09-13/S2A_USER_PRD_MSIL2A_PDMC_20160915T15\ |
  | 1344_R122_V20160913T100022_20160913T100504.SAFE/GRANULE/S2A_USER_MSI\ |
  | _L2A_TL_SGS__20160913T170505_A006411_T33UWR_N02.04/IMG_DATA/R20m/S2A\ |
  | _USER_MSI_L2A_TL_SGS__20160913T170505_A006411_T33UWR_B04_20m.jp2"
ou\   |
  |    tput="20160913_R122.3b" memory=300 offset=0
num_digits=0                |
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170406/7682522e/attachment.html>
