[GRASS-user] Temporal framework: calculating annual 5-day extremes
RichardCooper richtcooper at hotmail.com
Fri Apr 7 03:45:27 PDT 2017
Many thanks for the suggestions.
I'd really like to use the voxel approach but am getting the following error
on running t.rast.to.rast3 to create a voxel.
I've increased the hard and soft limits for open files to 40000 on my
system, but I still am unable to convert a space time raster dataset  into a
3D raster map with only 5000 raster layers (note: I have 50K daily raster
layers that I need to analyse i voxel)
$ cat /proc/sys/fs/file-max
800532
$ ulimit -Sn
400000
$ ulimit -Hn
400000
Thanks,
Richard
Creation of STRDS and error on trying to convert to 3D data set:
t.create output=capha_test_5 temporaltype=relative semantictype=max
title=cahpa_test_5 description=cahpa_test_5
t.register --overwrite --verbose input=capha_test_5 at cahpa
file=/home/rcooper/grassdatacl/climdata/cahpa/.tmp/rcooper-dell/3528.4
start=1 unit=day increment=1
Gathering map information...
Registering maps in the temporal database...
Registering maps in the space time dataset...
Updating space time dataset...
Update metadata, spatial and temporal extent from all registered maps of
<capha_test_5 at cahpa>
<capha_test at cahpa>
<capha_test_50 at cahpa>
<capha_test_25 at cahpa>
<capha_test_10 at cahpa>
t.rast.to.rast3 --overwrite --verbose input=capha_test_5 at cahpa
output=cahpa_test_5_3d
  File "/usr/local/grass-7.2.0/scripts/t.rast.to.rast3",
line 194, in <module>
    main()
line 152, in main
    output=output, overwrite=grass.overwrite())
  File
"/usr/local/grass-7.2.0/etc/python/grass/script/core.py",
line 408, in run_command
    ps = start_command(*args, **kwargs)
  File
line 377, in start_command
    return Popen(args, **popts)
  File
line 74, in __init__
    subprocess.Popen.__init__(self, args, **kwargs)
  File "/usr/lib/python2.7/subprocess.py", line 710, in
__init__
    errread, errwrite)
  File "/usr/lib/python2.7/subprocess.py", line 1327, in
_execute_child
    raise child_exception
OSError: [Errno 7] Argument list too long
(Fri Apr  7 17:30:33 2017) Command finished (2 sec)
View this message in context: http://osgeo-org.1560.x6.nabble.com/Temporal-framework-calculating-annual-5-day-extremes-tp5316014p5316291.html
Sent from the Grass - Users mailing list archive at Nabble.com.
