[GRASS-user] Temporal framework: calculating annual 5-day extremes
Sören Gebbert
soerengebbert at googlemail.com
Fri Apr 7 08:49:38 PDT 2017
Patching t.rast.to.rast3 to support file input requires the
modification of r.to.rast3 to implement file support. This may not
happen in the near future.
I would suggest to use t.rast.algebra or to compute the 5day rainfall
extrema in 5 year chunks using t.rast.to.rast3 + r3.mapcalc. Use
t.rast.extract and its "where" option to compute the 5year strds
chunks.
Best regards
Soeren
2017-04-07 13:37 GMT+02:00 Moritz Lennert <mlennert at club.worldonline.be>:
> On 07/04/17 12:45, RichardCooper wrote:
>> Many thanks for the suggestions.
>> I'd really like to use the voxel approach but am getting the following
>> error
>> on running t.rast.to.rast3 to create a voxel.
>> I've increased the hard and soft limits for open files to 40000 on my
>> system, but I still am unable to convert a space time raster dataset into
>> a
>> 3D raster map with only 5000 raster layers (note: I have 50K daily raster
>> layers that I need to analyse i voxel)
>> $ cat /proc/sys/fs/file-max
>> 800532
>> $ ulimit -Sn
>> 400000
>> $ ulimit -Hn
>> 400000
> AFAICT, the issue is not with the number of open files, but with a list of
> map names (arguments) that is too long for the run_command call that calls
> r.to.rast3. A solution to this could be to allow as input to r.to.rast3 a
> file with map names (such as for r.series).
> You should create a bug report for this.
> Moritz
>> Thanks,
>> Richard
>> Creation of STRDS and error on trying to convert to 3D data set:
>> t.create output=capha_test_5 temporaltype=relative semantictype=max
>> title=cahpa_test_5 description=cahpa_test_5
>> t.register --overwrite --verbose input=capha_test_5 at cahpa
>> file=/home/rcooper/grassdatacl/climdata/cahpa/.tmp/rcooper-dell/3528.4
>> start=1 unit=day increment=1
>> Gathering map information...
>> Registering maps in the temporal database...
>> Registering maps in the space time dataset...
>> Updating space time dataset...
>> Update metadata, spatial and temporal extent from all registered maps of
>> <capha_test_5 at cahpa>
>> <capha_test at cahpa>
>> <capha_test_50 at cahpa>
>> <capha_test_25 at cahpa>
>> <capha_test_10 at cahpa>
>> t.rast.to.rast3 --overwrite --verbose input=capha_test_5 at cahpa
>> output=cahpa_test_5_3d
>> Traceback (most recent call last):
>> File "/usr/local/grass-7.2.0/scripts/t.rast.to.rast3",
>> line 194, in <module>
>> main()
>> line 152, in main
>> output=output, overwrite=grass.overwrite())
>> File
>> "/usr/local/grass-7.2.0/etc/python/grass/script/core.py",
>> line 408, in run_command
>> ps = start_command(*args, **kwargs)
>> File
>> line 377, in start_command
>> return Popen(args, **popts)
>> File
>> line 74, in __init__
>> subprocess.Popen.__init__(self, args, **kwargs)
>> File "/usr/lib/python2.7/subprocess.py", line 710, in
>> __init__
>> errread, errwrite)
>> File "/usr/lib/python2.7/subprocess.py", line 1327, in
>> _execute_child
>> raise child_exception
>> OSError: [Errno 7] Argument list too long
>> (Fri Apr 7 17:30:33 2017) Command finished (2 sec)
>> View this message in context:
>> http://osgeo-org.1560.x6.nabble.com/Temporal-framework-calculating-annual-5-day-extremes-tp5316014p5316291.html
>> Sent from the Grass - Users mailing list archive at Nabble.com.
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-user
