[GRASS-user] i.group error
Nikos Alexandris
nik at nikosalexandris.net
Thu Apr 20 00:47:00 PDT 2017
* Joseph Kariuki <joehene at gmail.com> [2017-04-20 09:20:39 +0300]:
>I am trying to group raster layers using thre following
>from grass.pygrass.gis import Mapset
>m = Mapset('hempire')
Instead (did not try it!):
m = Mapset()
mapset = Mapset('hempire')
Then use the 'mapset' if/whenever required to feed the Mapset's name
elsewhere.
Nikos
>grass.run_command("i.group", group="lamu", subgroup="lamusubgrp",
>input=m.glist("raster", pattern="LE07_*"))
>However, this error is being raised
>ImportError: No module named mapset
>Am I supposed to import something else besides mapset??
>Kind Regards,
>*Joseph Kariuki*
>*Geospatial Engineer** | **GIS / Web Developer*
