[GRASS-user] i.group error
Joseph Kariuki joehene at gmail.com
Thu Apr 20 02:02:12 PDT 2017
It think it is accessible. Here's the error message
  File "/home/hempire/PycharmProjects/GRASSproject/landsatProcessing.py",
line 155, in <module>
    from grass.pygrass.gis import Mapset
  File
"/usr/local/grass-7.2.1svn/etc/python/grass/pygrass/gis/__init__.py", line
13, in <module>
    import grass.lib.gis as libgis
  File "/usr/local/grass-7.2.1svn/etc/python/grass/lib/gis.py", line 23, in
<module>
    _libs["grass_gis.7.2.1svn"] = load_library("grass_gis.7.2.1svn")
  File "/usr/local/grass-7.2.1svn/etc/python/grass/lib/ctypes_loader.py",
line 62, in load_library
    return self.load(path)
line 78, in load
    raise ImportError(e)
ImportError: libgrass_datetime.7.2.1svn.so: cannot open shared object file:
No such file or directory
Process finished with exit code 1
Kind Regards,
*Joseph Kariuki*
*Geospatial Engineer** | **GIS / Web Developer*
On Thu, Apr 20, 2017 at 11:43 AM, Nikos Alexandris <nik at nikosalexandris.net>
wrote:
> Please keep the discussion public.
> The "from" line seems correct to me.  You should ensure that pygrass is
> accessible.
> Please post again in the list.
> Nikos
> * Joseph Kariuki <joehene at gmail.com> [2017-04-20 11:16:33 +0300]:
> Hi Nikos,
>> The problem is that there is no Mapset module in pygrass. How can I
>> include
>> the Mapset or alternatively, how can I group the rasters that I have here
>> Kind Regards,
>> *Joseph Kariuki*
>> On Thu, Apr 20, 2017 at 10:47 AM, Nikos Alexandris <
>> wrote:
>> * Joseph Kariuki <joehene at gmail.com> [2017-04-20 09:20:39 +0300]:
>>> I am trying to group raster layers using thre following
>>>> m = Mapset('hempire')
>>> Instead (did not try it!):
>>> m = Mapset()
>>> mapset = Mapset('hempire')
>>> Then use the 'mapset' if/whenever required to feed the Mapset's name
>>> elsewhere.
>>> Nikos
>>> grass.run_command("i.group", group="lamu", subgroup="lamusubgrp",
>>>> input=m.glist("raster", pattern="LE07_*"))
>>>> However, this error is being raised
>>>> ImportError: No module named mapset
>>>> Am I supposed to import something else besides mapset??
>>>> Kind Regards,
>>>> *Joseph Kariuki*
> Nikos Alexandris | Remote Sensing & Geomatics
> GPG Key Fingerprint 6F9D4506F3CA28380974D31A9053534B693C4FB3
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170420/4a7394be/attachment.html>
