[GRASS-user] r.import extent=region ignored
Tomáš Brunclík
brunclik at atlas.cz
Thu Apr 20 05:30:41 PDT 2017
Thank you for information, when it is released, it would be exactly what
I was missing.
In the meantime, I created simple script tailored for my purposes to
import a multiband raster file (I am working with Sentinel level-2 data
with .vrt virtual raster created inside the SAFE directory with .jp2
files via gdalbuildvrt tool). It uses r.external, then sets the region
using extent of GRASS vector map (I use a vector rectangle delineating
my area of interest stored in the PERMANENT mapset) and pixel aligning
to the imported raster, then clipping it creating output raster. The
imported bands are added to group of the same name as the base name,
bands are numbered by suffixes .1 .2 .3.... The script is not able
import directory of band rasters, only single multiband file, but it
should be easy to enhance it in this way.
For anyone interested, here it is, it can be run through the button to
run a user script:
https://www.dropbox.com/s/y80b07yvso1snux/r.clipimport.py?dl=0
Regards,
Tomas B.
Anna Petrášová napsal(a):
> Once this the ticket below is solved, it will be integrated to r.import:
> https://trac.osgeo.org/grass/ticket/2055
> Best,
> Anna
> On Thu, Apr 6, 2017 at 3:09 PM, Veronica Andreo <veroandreo at gmail.com> wrote:
>> Correction: it is mentioned under 'known issues'... :)
>> Vero
>> El 6 abr. 2017 9:05 p. m., "Veronica Andreo" <veroandreo at gmail.com>
>> escribió:
>> Hello Thomas,
>> If the map you are importing has the same projection than the location, then
>> extent parameter is ignored. It is not a bug, but how the module works. It
>> is written in the 'Notes' section, I think. The extent parameter works only
>> when map and target location have different reference systems.
>> Best,
>> Vero
>> El 6 abr. 2017 8:59 p. m., "Tomáš Brunclík" <brunclik at atlas.cz> escribió:
>> Hello,
>> Using GRASS 7.2.1svn r70842 (Linux 64bit from today's binary snapshot) and
>> it seems the extent=region parameter of the r.import is just ignored. Tried
>> from GUI, then from command line, first with multi band virtual raster, then
>> with single JPEG2000 file (as in the example below), with and without the -n
>> option. Is it a known bug, or does it work for someone, perhaps in some
>> other version, or with other input formats? I tried to look in trac, but did
>> not see anything. I am aware how I can clip the rasters after import, but it
>> seemed one of the fine new features which would make the daily use a little
>> more comfortable...
>> Tomas Brunclik
>> GRASS 7.2.1svn (utm33n):~ > r.import -o
>> input=/home/tom/GISdata/DPZ/Chlorofyl-vzorkovani/2016-09-13_R122_S2A_samping_09-13/S2A_USER_PRD_MSIL2A_PDMC_20160915T151344_R122_V20160913T100022_20160913T100504.SAFE/GRANULE/S2A_USER_MSI_L2A_TL_SGS__20160913T170505_A006411_T33UWR_N02.04/IMG_DATA/R20m/S2A_USER_MSI_L2A_TL_SGS__20160913T170505_A006411_T33UWR_B04_20m.jp2
>> output=20160913_R122.3b extent=region
>> UPOZORNĚNÍ: Přeskakuje se kontrola kartografického zobrazení.
>> Proceeding with import of 1 raster bands...
>> Importing raster map <20160913_R122.3b>...
>> 100%
>> GRASS 7.2.1svn (utm33n):~ > g.region -p
>> projection: 1 (UTM)
>> zone: 33
>> datum: wgs84
>> ellipsoid: a=6378137 es=0.00669438
>> north: 5569000
>> south: 5543320
>> west: 531260
>> east: 570320
>> nsres: 20
>> ewres: 20
>> rows: 1284
>> cols: 1953
>> cells: 2507652
>> GRASS 7.2.1svn (utm33n):~ > r.info map=20160913_R122.3b
>> | Map: 20160913_R122.3b Date: Thu Apr 6 20:27:43 2017
>> | Mapset: sentinel2test Login of Creator: tom
>> | Location: utm33n
>> | DataBase: /home/tom/GISdata/grass
>> | Title:
>> | Timestamp: none
>> | Type of Map: raster Number of Categories: 0
>> | Data Type: CELL
>> | Rows: 5490
>> | Columns: 5490
>> | Total Cells: 30140100
>> | Projection: UTM (zone 33)
>> | N: 5600040 S: 5490240 Res: 20
>> | E: 609780 W: 499980 Res: 20
>> | Range of data: min = 1 max = 17010
>> | Data Description:
>> | generated by r.in.gdal
>> | Comments:
>> | r.in.gdal -o -k input="/home/tom/GISdata/DPZ/Chlorofyl-vzorkovani/20\
>> | 16-09-13_R122_S2A_samping_09-13/S2A_USER_PRD_MSIL2A_PDMC_20160915T15\
>> | 1344_R122_V20160913T100022_20160913T100504.SAFE/GRANULE/S2A_USER_MSI\
>> | _L2A_TL_SGS__20160913T170505_A006411_T33UWR_N02.04/IMG_DATA/R20m/S2A\
>> | _USER_MSI_L2A_TL_SGS__20160913T170505_A006411_T33UWR_B04_20m.jp2" ou\
>> | tput="20160913_R122.3b" memory=300 offset=0 num_digits=0
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-user
