[GRASS-user] r.import extent=region ignored
Martin Landa
landa.martin at gmail.com
Thu Apr 20 08:10:49 PDT 2017
2017-04-20 14:30 GMT+02:00 Tomáš Brunclík <brunclik at atlas.cz>:
> For anyone interested, here it is, it can be run through the button to run a
> user script:
> https://www.dropbox.com/s/y80b07yvso1snux/r.clipimport.py?dl=0
there is patch which allows limit r.in.gdal to current region, see [1]. Ma
[1] https://trac.osgeo.org/grass/ticket/2055
>>> | DataBase: /home/tom/GISdata/grass
>>> | Title:
>>> | Timestamp: none
>>> | Type of Map: raster Number of Categories: 0
>>> | Data Type: CELL
>>> | Rows: 5490
>>> | Columns: 5490
>>> | Total Cells: 30140100
>>> | Projection: UTM (zone 33)
>>> | N: 5600040 S: 5490240 Res: 20
>>> | E: 609780 W: 499980 Res: 20
>>> | Range of data: min = 1 max = 17010
>>> | Data Description:
>>> | generated by r.in.gdal
>>> | Comments:
>>> | r.in.gdal -o -k
>>> input="/home/tom/GISdata/DPZ/Chlorofyl-vzorkovani/20\
>>> 16-09-13_R122_S2A_samping_09-13/S2A_USER_PRD_MSIL2A_PDMC_20160915T15\
>>> 1344_R122_V20160913T100022_20160913T100504.SAFE/GRANULE/S2A_USER_MSI\
>>> _L2A_TL_SGS__20160913T170505_A006411_T33UWR_N02.04/IMG_DATA/R20m/S2A\
>>> | _USER_MSI_L2A_TL_SGS__20160913T170505_A006411_T33UWR_B04_20m.jp2"
>>> ou\
>>> | tput="20160913_R122.3b" memory=300 offset=0 num_digits=0
>>> GRASS 7.2.1svn (utm33n):~ >
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/grass-user
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
