[GRASS-user] v.out.ogr with -spat?
    Moritz Lennert
    mlennert at club.worldonline.be
    Fri Aug 18 00:08:49 PDT 2017
On 18/08/17 07:36, Jeshua Lacock wrote:
> Greetings,
> I have huge vector databases (~50 million records) that I need to export as many tens of thousands of tiles.
> Is it possible to use ogr2ogr’s spat argument when exporting with v.out.ogr, perhaps using its’ dsco or lco arguments?
AFAIK, no.
Seems like an interesting thing to have. Maybe you could make an
enhancement request for this in the bug tracker ?
> Otherwise, is there a faster (more efficient) way than creating a new vector with v.select? v.select seems several magnitudes slower than if I export to a huge sqlite database and the use ogr2ogr’s -spat argument, but I would prefer to keep it in GRASS.
See https://trac.osgeo.org/grass/ticket/3361 for a report of the slow
v.select. This is mostly when using the GEOS operators, not when using
the native overlap operator. Is this what you are doing ? It would be
good if you could add your experience to the above enhancement request.
Moritz
