[GRASS-user] d.rast.edit with multiple maps
Ken Mankoff mankoff at gmail.com
Sun Aug 20 04:46:41 PDT 2017
On Sun, Aug 20, 2017 at 1:23 PM, Helmut Kudrnovsky <hellik at web.de> wrote:
> [please keep conversation on the ML, that other can benefit ]
Yes of course. For some reason GMail defaulted to "reply" instead of "reply
to all"
> > I'm using GRASS on the CLI
> How will you do visually raster editing on the CLI?
I typically call d.rast and d.vect and etc. from the CLI, and when first
trying d.rast.edit did that from CLI too. Yes those commands do bring up a
window. Thanks for your advice below, I will look into the larger GRASS
wxGUI for the transparency.
Anyway, I expect this will help, but may not be a complete solution... I'd
like to be able to examine multiple rasters while editing 1 (or >1).
Something like g.gui.mapswipe, but with more linked maps, would be good. It
seems this needs to be a custom tool I write, perhaps using the Python API.
Thanks again for the hint about transparency,
   -k.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170820/35f90a41/attachment.html>
