[GRASS-user] d.rast.edit with multiple maps
Ken Mankoff
mankoff at gmail.com
Sun Aug 20 07:36:13 PDT 2017
I'm able to start the "Raster Digitizer" tool, but then cannot do anything.
A second toolbar opens and the mouse cursor changes to a pen (edit mode?),
but when I click on the map, I get a dialog that says, "Please select the
first raster map". I'm not sure where/what/how to select this, and I have
been unable to find documentation about this new tool.
How would one go about removing a hill from a DEM? I imagine drawing a new
raster by digitizing an area, then using it to set the hill region in the
DEM to NULL, then interpolating the DEM to fill in the now-removed hill.
Does this seem like a reasonable workflow?
Thanks,
-k.
On Sun, Aug 20, 2017 at 1:46 PM, Ken Mankoff <mankoff at gmail.com> wrote:
> On Sun, Aug 20, 2017 at 1:23 PM, Helmut Kudrnovsky <hellik at web.de> wrote:
>> [please keep conversation on the ML, that other can benefit ]
> Yes of course. For some reason GMail defaulted to "reply" instead of
> "reply to all"
>> > I'm using GRASS on the CLI
>> How will you do visually raster editing on the CLI?
> I typically call d.rast and d.vect and etc. from the CLI, and when first
> trying d.rast.edit did that from CLI too. Yes those commands do bring up a
> window. Thanks for your advice below, I will look into the larger GRASS
> wxGUI for the transparency.
> Anyway, I expect this will help, but may not be a complete solution... I'd
> like to be able to examine multiple rasters while editing 1 (or >1).
> Something like g.gui.mapswipe, but with more linked maps, would be good. It
> seems this needs to be a custom tool I write, perhaps using the Python API.
> Thanks again for the hint about transparency,
> -k.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170820/f09a8b63/attachment.html>
