[GRASS-user] ST{R,V}DS in different mapsets
Sören Gebbert
soerengebbert at googlemail.com
Tue Dec 5 05:22:21 PST 2017
Dear Ken,
you have to add the required mapset to your mapset search path using
g.mapsets. This is a feature of the temporal framework to check only
for temporal databases of mapsets in your current mapset search path.
Best regards
Sören
2017-12-05 13:56 GMT+01:00 Ken Mankoff <mankoff at gmail.com>:
> Dear GRASS List,
> I'm working with some STRDS and STVDS and having trouble accessing an STRDS located in a different mapset.
> I can provide a full MWE, but briefly:
> t.sample inputs=bar sample=foo at foo intype=strds samtype=strds method=contain
> Reports:
> ERROR: Unable to execute sql statement. You have no permission to access
> mapset <foo>, or mapset <foo> has no temporal database. Accessible mapsets
> are: <bar>
> Is this the expected behavior? I use different mapsets a lot to organize the many rasters and vectors from different parts of the project, and I'd hate to have to work all in one place just to use the time series features.
> Thanks,
> -k.
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
