[GRASS-user] r.watershed
Marco Alicera
marco.alicera at gmail.com
Wed Dec 6 03:42:49 PST 2017
How did you add culverts?!
Such a great question and I also wonder how you did. Short ago I knew about
Itzï and its ability to do it with SWMM
http://itzi.readthedocs.io/en/latest/tutorial.html#culvert-modelling.
Looking forward to testing it
Marco
2017-12-06 9:24 GMT+01:00 Shane Carey <careyshan at gmail.com>:
> Hi Mark,
> Thanks for your reply! Sounds great.
> How did you add culverts or other artificial flow control features to
> achieve water flowing through roads?
> I have a rivers layer and I compared it the streams I've obtained from
> r.watershed and r.watershed appears to not match these streams (which were
> accurately digitised) and I was wondering if I had a better resolution DTM
> would it solve this problem?
> Also, why is sink filling needed for terraflow and not watershed?
> Thanks for your help :-)
> On Máirt 5 Noll 2017 at 23:43, Mark Seibel <mseibel at gmail.com> wrote:
>> Hi Shane.
>> I'm happy to report that I've modeled overland water flow with
>> r.watershed for over a quarter million acres, consisting of several large
>> project sites, at 1 meter DEM resolution. The data source was LiDAR
>> points to make the DEMs.
>> At this resolution, it becomes necessary to add culverts, or other
>> artificial flow control features, to achieve water flowing through a road.
>> Otherwise, water is routed along roads until a lowest point is reached for
>> crossing.
>> I also use r.terraflow outputs as ancillary data to help drop in culvert
>> locations and help provide guidance in problem areas.
>> My geographic area is central Florida, which is very flat and full of
>> topographic depressions known as wetlands. These depressions interrupt the
>> stream network continuity in reality, but r.watershed does a fantastic job
>> making a continuous drainage network model, especially in these difficult
>> areas.
>> Happy Modeling!
>> Mark
>> On Tue, Dec 5, 2017, 3:49 PM Shane Carey <careyshan at gmail.com> wrote:
>>> Hi,
>>> I am trying to extract river network from a 5m DEM with some success
>>> using r.watershed. Has anyone tested this algorithm on high resolution
>>> LiDAR data for example - 1meter DTM and what kind of results have they
>>> obtained?
>>> Thanks
>>> Le gach dea ghui,
>>> *Shane Carey*
>>> *GIS and Data Solutions Consultant*
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/grass-user
> Le gach dea ghui,
> *Shane Carey*
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20171206/69b94f71/attachment-0001.html>
