[GRASS-user] Strange behavior with v.patch
Peter Tittmann
ptittmann at gmail.com
Mon Dec 11 15:16:01 PST 2017
Thanks, Markus. That solves the problem.
On Sat, Dec 9, 2017, 8:33 AM Markus Metz <markus.metz.giswork at gmail.com>
wrote:
> On Fri, Dec 8, 2017 at 11:46 PM, Peter Tittmann <ptittmann at gmail.com>
> wrote:
> > Hi,
> > In attempting to patch two polygon layers I am confused as to the the
> results i am getting. My understanding of v.patch is that it would be
> similar to a `union` operator in SQL (not a spatial union) wherein rows of
> one or many tables are concatenated to a new table. However, the results
> i’m getting are not in aligned with that expectation.
> > Here is a link to an image of the two tables (one orange, one green) (
> https://pasteboard.co/GXjWm6P.png )
> > The second image ( https://pasteboard.co/GXjVSQE.png) is a result of
> > # combine all clustered polygons into one table
> > gsc.parse_command('v.patch',
> > flags = 'e',
> > overwrite = True,
> > verbose= True,
> > input = <green>, <orange>,
> > output = ssPoly)
> > The blue represents the result of the v.patch command. I don't
> understand why all of the area covered by the two source vectors is not
> covered in the patched vector.
> You have patched two area vectors together and the output contains most
> likely topological errors. Try to clean the output of v.patch with v.clean
> -c tool=break type=boundary.
> HTH,
> Markus M
> > My only thought it it has something to do with the categories, or keys?
> > Thanks in advance for any guidance.
> > Peter
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20171211/214431c2/attachment.html>
