[GRASS-user] Behavior difference: g.list and g.remove
Rich Shepard
rshepard at appl-ecosys.com
Thu Dec 14 08:18:55 PST 2017
Running 7.5.svn (r71933) on Slackware-14.2. Using g.remove without the
'-f' option to check which files would be removed does not find the same
files found by g.list:
> g.list type=rast pattern=blocked1_*
blocked1_h_0000
blocked1_h_0001
blocked1_h_0002
blocked1_h_0003
blocked1_h_max
[Raster MASK present]
> g.remove type=rast pattern=blocked1_*
The following data base element files would be deleted:
WARNING: No data base element files found
Is this a user error?
Rich
