[GRASS-user] i.atcorr with Sentinel2
Stefan Blumentrath Stefan.Blumentrath at nina.no
Tue Dec 19 14:08:06 PST 2017
Thanks Markus for the hint, and many thanks Sajid for your continuous support!
Now, I compiled both GRASS 7.4 and 7.5 on Ubuntu 14.04 (gcc (Ubuntu 4.8.4-2ubuntu1~14.04.1) 4.8.4).
I configured with the parameters Sajid sent and dropped all optimisation flags.
However, the result is still the same for both versions: Only NULL cells from i.atcorr with Sentinel-2
On my Ubuntu 16.04 box I only have a package-install from UbunutGIS experimental, which also fails.
To test a completely different system I also tested GRASS 7.5 (daily) and 7.4.0RC1 on OSGeo4W. Both fail as well.
For completeness: I could not get Sajids data to work for me either.
Sajid, which code revision are you using? Maybe a change somewhere else interferes?
Or would you mind trying the release candidate?
Cheers
Stefan
-----Original Message-----
From: neteler.osgeo at gmail.com [mailto:neteler.osgeo at gmail.com] On Behalf Of Markus Neteler
Sent: tirsdag 19. desember 2017 20.38
To: Stefan Blumentrath <Stefan.Blumentrath at nina.no>
Cc: GRASS user list <grass-user at lists.osgeo.org>
Subject: Re: [GRASS-user] i.atcorr with Sentinel2
On Tue, Dec 19, 2017 at 4:58 PM, Stefan Blumentrath <Stefan.Blumentrath at nina.no> wrote:
> Given that the i.atcorr code did not change the last ½ year and given
> that you succeeded with current trunk as well (also with my data), I
> am afraid I have to conclude this is an issue of my local installation.
> Does anyone know if an underlying library can be causing trouble or
> what parts of my setup I would have to look for?
How did you compile the version? Perhaps a compiler optimization is creating troubles?
Which operating system, which compiler, etc?
Markus
