[GRASS-user] i.atcorr with Sentinel2
Sajid Pareeth
spareeth at gmail.com
Wed Dec 20 06:31:19 PST 2017
Hi Stefan
I tested your data in different versions.
Now, I compiled both GRASS 7.4 and 7.5 on Ubuntu 14.04 (gcc (Ubuntu
> 4.8.4-2ubuntu1~14.04.1) 4.8.4).
I get the same output (with numbers) for both compiled 7.4 and 7.5
in Ubuntu 16.04.3 LTS (gcc version 5.4.0 20160609 (Ubuntu
5.4.0-6ubuntu1~16.04.5)).
> To test a completely different system I also tested GRASS 7.5 (daily) and
> 7.4.0RC1 on OSGeo4W. Both fail as well.
I tried both daily and 7.4.0RC1 in windows 7, installed using OSGeo4W.
Here I get different results:
With GRASS GIS 7.5.svn (r71953), I get NULL output.
With GRASS GIS 7.4 RC1 (r71752), the i.atcorr process crashed with
following error:
> *GRASS 7.4.svn> i.atcorr -r input=s2a_b8 range=0,10000 elevation=dem
> parameters=p6s.txt output=s2a_b8_corr_2 rescale=0,10000WARNING: Request for
> unsupported compressorWARNING: Request for unsupported
> compressorAtmospheric correction...ERROR: Request for unsupported
> compressor*
> Sajid, which code revision are you using? Maybe a change somewhere else
> interferes?
In Ubuntu, I used r71952 (latest trunk).
Sajid
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20171220/db5f66ca/attachment-0001.html>
