[GRASS-user] grass72 or higher on RHEL6
    Markus Neteler
    neteler at osgeo.org
    Thu Feb  2 01:15:04 PST 2017
Hi Joerg,
On Thu, Feb 2, 2017 at 9:47 AM, joerg robl <joerg.robl at gmail.com> wrote:
> Dear Martin,
> Thank you for you help!
> Below are the error messages.
> cheers Jörg
> GRASS 7.3.svn (xy):/usr/local/src/GRASS/grass7_trunk/display/d.linegraph >
> make
> VERSION_NUMBER=7.3.svn
> /usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/tools/g.html2man.py
> /usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/html/d.linegraph.html
> /usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/man/man1/d.linegraph.1
> Traceback (most recent call last):
>   File
> "/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/tools/g.html2man.py",
> line 77, in <module>
>     main()
>   File
> line 56, in main
>     p.close()
>   File "/usr/lib64/python2.6/HTMLParser.py", line 112, in close
>     self.goahead(1)
>   File "/usr/lib64/python2.6/HTMLParser.py", line 164, in goahead
>     self.error("EOF in middle of construct")
>   File "/usr/lib64/python2.6/HTMLParser.py", line 115, in error
>     raise HTMLParseError(message, self.getpos())
> HTMLParser.HTMLParseError: EOF in middle of construct, at line 69, column 8
> make: ***
> [/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/man/man1/d.linegraph.1]
> Error 1
The HTML was broken in the manual page. I have fixed that in trunk r70474.
Please update from SVN.
Can you then also check the other directories:
/usr/local/src/GRASS/grass7_trunk/display/d.barscale
/usr/local/src/GRASS/grass7_trunk/display/d.northarrow
/usr/local/src/GRASS/grass7_trunk/display/d.vect
/usr/local/src/GRASS/grass7_trunk/raster/r.colors
/usr/local/src/GRASS/grass7_trunk/vector/v.colors
/usr/local/src/GRASS/grass7_trunk/temporal/t.rast.colors
/usr/local/src/GRASS/grass7_trunk/man
with changing into then and run "make"?
thanks,
Markus
