[GRASS-user] grass72 or higher on RHEL6
    joerg robl
    joerg.robl at gmail.com
    Thu Feb  2 01:39:12 PST 2017
Dear Markus
Thank you for your help!
Ok, I've update to 70474
[jrobl at geo1 grass7_trunk]$ svn up
At revision 70474.
I did make clean, configure and make to recompile grass73
The errors still remain
Errors in:
/usr/local/src/GRASS/grass7_trunk/display/d.barscale
/usr/local/src/GRASS/grass7_trunk/display/d.linegraph
/usr/local/src/GRASS/grass7_trunk/display/d.northarrow
/usr/local/src/GRASS/grass7_trunk/display/d.vect
/usr/local/src/GRASS/grass7_trunk/raster/r.colors
/usr/local/src/GRASS/grass7_trunk/vector/v.colors
/usr/local/src/GRASS/grass7_trunk/temporal/t.rast.colors
/usr/local/src/GRASS/grass7_trunk/man
I manually changed to the directories and did "make". See below!
cheers Jörg
[jrobl at geo1 d.barscale]$ make
VERSION_NUMBER=7.3.svn
/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/tools/
g.html2man.py
/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/html/d.barscale.html
/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/man/man1/d.barscale.1
  File "/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/tools/
g.html2man.py", line 77, in <module>
    main()
g.html2man.py", line 56, in main
    p.close()
  File "/usr/lib64/python2.6/HTMLParser.py", line 112, in close
    self.goahead(1)
  File "/usr/lib64/python2.6/HTMLParser.py", line 164, in goahead
    self.error("EOF in middle of construct")
  File "/usr/lib64/python2.6/HTMLParser.py", line 115, in error
    raise HTMLParseError(message, self.getpos())
HTMLParser.HTMLParseError: EOF in middle of construct, at line 54, column 8
make: ***
[/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/man/man1/d.barscale.1]
Error 1
[jrobl at geo1 d.linegraph]$ make
g.html2man.py
/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/html/d.linegraph.html
/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/man/man1/d.linegraph.1
    main()
    p.close()
    self.goahead(1)
HTMLParser.HTMLParseError: EOF in middle of construct, at line 69, column 8
make: ***
[/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/man/man1/d.linegraph.1]
Error 1
[jrobl at geo1 d.northarrow]$ make
g.html2man.py
/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/html/d.northarrow.html
/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/man/man1/d.northarrow.1
    main()
    p.close()
    self.goahead(1)
make: ***
[/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/man/man1/d.northarrow.1]
Error 1
[jrobl at geo1 d.vect]$ make
g.html2man.py
/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/html/d.vect.html
/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/man/man1/d.vect.1
    main()
    p.close()
    self.goahead(1)
HTMLParser.HTMLParseError: EOF in middle of construct, at line 104, column 8
make: ***
[/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/man/man1/d.vect.1]
Error 1
[jrobl at geo1 r.colors]$ make
g.html2man.py
/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/html/r.colors.html
/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/man/man1/r.colors.1
    main()
    p.close()
    self.goahead(1)
HTMLParser.HTMLParseError: EOF in middle of construct, at line 72, column 8
make: ***
[/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/man/man1/r.colors.1]
Error 1
[jrobl at geo1 v.colors]$ make
g.html2man.py
/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/html/v.colors.html
/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/man/man1/v.colors.1
    main()
    p.close()
    self.goahead(1)
HTMLParser.HTMLParseError: EOF in middle of construct, at line 91, column 8
make: ***
[/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/man/man1/v.colors.1]
Error 1
[jrobl at geo1 t.rast.colors]$ make
g.html2man.py
/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/html/t.rast.colors.html
/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/man/man1/t.rast.colors.1
    main()
    p.close()
    self.goahead(1)
HTMLParser.HTMLParseError: EOF in middle of construct, at line 68, column 8
make: ***
[/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/man/man1/t.rast.colors.1]
Error 1
[jrobl at geo1 man]$ make
Generating HTML manual pages index (help system)...
make
/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/html/full_index.html
/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/html/index.html
/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/html/topics.html
/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/html/keywords.html
/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/html/graphical_index.html
/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/html/manual_gallery.html
/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/html/class_graphical.html
/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/html/parser_standard_options.html
/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/html/display.html
/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/html/database.html
/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/html/general.html
/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/html/imagery.html
/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/html/miscellaneous.html
/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/html/postscript.html
/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/html/raster.html
/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/html/raster3d.html
/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/html/temporal.html
/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/html/vector.html
make[1]: Entering directory `/usr/local/src/GRASS/grass7_trunk/man'
make[1]:
`/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/html/full_index.html'
is up to date.
make[1]:
`/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/html/index.html'
is up to date.
make[1]:
`/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/html/topics.html'
is up to date.
make[1]:
`/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/html/keywords.html'
is up to date.
GISBASE="/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu"
ARCH="x86_64-pc-linux-gnu"
ARCH_DISTDIR="/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu"
VERSION_NUMBER=7.3.svn VERSION_DATE=2017 python ./build_graphical_index.py
  File "./build_graphical_index.py", line 93, in <module>
    ('raster_graphical.html', std_img_name('raster'), 'Raster'),
  File "./build_graphical_index.py", line 89, in std_img_name
    return "gi_{}.jpg".format(name)
ValueError: zero length field name in format
make[1]: ***
[/usr/local/src/GRASS/grass7_trunk/dist.x86_64-pc-linux-gnu/docs/html/graphical_index.html]
Error 1
make[1]: Leaving directory `/usr/local/src/GRASS/grass7_trunk/man'
make: *** [default] Error 2
2017-02-02 10:15 GMT+01:00 Markus Neteler <neteler at osgeo.org>:
> Hi Joerg,
> On Thu, Feb 2, 2017 at 9:47 AM, joerg robl <joerg.robl at gmail.com> wrote:
> > Dear Martin,
> > Thank you for you help!
> > Below are the error messages.
> > cheers Jörg
> > GRASS 7.3.svn (xy):/usr/local/src/GRASS/grass7_trunk/display/d.linegraph
> > make
> g.html2man.py
> >   File
> g.html2man.py",
> >     main()
> >   File
> g.html2man.py",
> > line 56, in main
> >     p.close()
> >     self.goahead(1)
> column 8
> > make: ***
> > Error 1
> The HTML was broken in the manual page. I have fixed that in trunk r70474.
> Please update from SVN.
> Can you then also check the other directories:
> with changing into then and run "make"?
> thanks,
> Markus
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170202/55fd05b3/attachment-0001.html>
