[GRASS-user] grass72 or higher on RHEL6
joerg robl
joerg.robl at gmail.com
Thu Feb 2 10:24:59 PST 2017
Dear Vaclav,
I tried r70477 but the errors did not disappear :-( . I also tried your
"cryptic" grep command and recompiled the code. However, the errors are
still there.
To rule out that this is an issue of our server I tried to compile r70477
on a CentOS6.8 Notebook. The compilation ended with the same errors, which
means that this problem will occur on all old Redhat, Fedora and CentOS
installations.
Thank you for your help!
cheers
Jörg
2017-02-02 16:46 GMT+01:00 Vaclav Petras <wenzeslaus at gmail.com>:
> On Thu, Feb 2, 2017 at 9:40 AM, Vaclav Petras <wenzeslaus at gmail.com>
> wrote:
>> On Thu, Feb 2, 2017 at 2:47 AM, joerg robl <joerg.robl at gmail.com> wrote:
>>> ret.append('name={}'.format(tnode.get('name').strip()))
>>> ValueError: zero length field name in format
>> This is Python 2.6 versus 2.7. I'll look into that.
> Please (thoroughly) test r70476.
> https://trac.osgeo.org/grass/changeset/70476
> I did the basic changes using the following command:
> for F in `grep --exclude-dir={.svn,.git,OBJ.*
> ,locale,dist.*,html,latex,build} -IrnE "\{\}.*format" | grep -Ev "\s#" |
> sed -e "s+\([^:]*\).*+\1+g" | grep -E "\.py$" | uniq`; do sed -ie
> "s+\({}\)\([^{}]*\.format\)+{0}\2+g" $F; done;
> and then reviewed the rest using:
> grep --exclude-dir={.svn,.git,OBJ.*,locale,dist.*,html,latex,build} -IrnE
> Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170202/0efa76e6/attachment.html>
