[GRASS-user] grass72 or higher on RHEL6
Vaclav Petras wenzeslaus at gmail.com
Thu Feb 2 12:05:33 PST 2017
On Thu, Feb 2, 2017 at 1:24 PM, joerg robl <joerg.robl at gmail.com> wrote:
> I tried r70477 but the errors did not disappear :-( . I also tried your
> "cryptic" grep command and recompiled the code. However, the errors are
> still there.
Did you try trunk (7.3)? Since the lines changed the errors can't be
exactly the same (the line is a part of the error message). There might be
some other errors. If that's the case, please post them.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170202/227a074c/attachment.html>
