[GRASS-user] Problem installing grass7 AddOn
Helmut Kudrnovsky
hellik at web.de
Thu Feb 9 12:08:02 PST 2017
Hi Anna,
Anna Muñoz wrote
> Hi all,
> I have just installed r.sun.daily grass addon following the instructions
> described in https://grasswiki.osgeo.org/wiki/AddOns.
> As you can see in the console message the installation was successful:
> (Thu Feb 09 12:56:20 2017)
> g.extension extension=r.sun.daily operation=add
> Downloading precompiled GRASS Addons
> <r.sun.daily>
> Updating addons metadata file...
> Installation of
> <r.sun.daily>
> successfully finished
> (Thu Feb 09 12:56:22 2017) Command finished (2 sec)
> Also, if I check the list of extensions installed I get this result:
> C:\> g.extension -a
> List of installed extensions
> <modules>
> r.sun.daily
> But, when I try to execute r.sun.daily inside a python script it seems
> like
> the addon was not installed.
> As a example, this is the command that I have been using ...
> gscript.run_command("r.sun.daily", flags = "t", elevation = "dsm", aspect
> "aspect", slope = "slope", ... )
> And this is the error message:
> OSError: Cannot find the executable r.sun.daily
> should i have to do anything more to finish the installation properly ?
just tested here with
System Info
GRASS version: 7.3.svn
GRASS SVN revision: r70508
Build date: 2017-01-09
Build platform: x86_64-w64-mingw32
GDAL: 2.1.2
PROJ.4: 4.9.3
GEOS: 3.5.0
SQLite: 3.14.1
Python: 2.7.5
wxPython: 2.8.12.1
Platform: Windows-8-6.2.9200 (OSGeo4W)
I've installed r.sun.daily by g.extension, g.extension -a showed the
installed addon,
but a look in C:\Users\your_user_name\AppData\Roaming\GRASS7\addons\scripts,
where the addon are stored, there was no installed r.sun.daily addon.
check in your addon folder if the addon is installed.
my next steps were:
g.gisenv set=DEBUG=3
have a look in the debug output if there is some warning/error message
during installation.
here on my side, with DEBUG=3 the addon was installed then.
then I've done g.gisenv set=DEBUG=0
deinstalled the addon and installed r.sun.daily again, checked it in
the addon was installed correctly.
please try the steps above and report back.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-installing-grass7-AddOn-tp5307176p5307268.html
Sent from the Grass - Users mailing list archive at Nabble.com.
