[GRASS-user] Question to the input seed grid of i.segment
Moritz Lennert
mlennert at club.worldonline.be
Fri Feb 10 09:41:21 PST 2017
Hi Raphael,
On 10/02/17 12:08, Raphael Knevels wrote:
> Hello Moritz,
> thank you for your help, and sorry for my late response to this
> topic.
> The slic algorithm works really great :-) for my image (... which is
> a slope) it needs around 27 minutes (11 000 superpixels and 0.6
> compactness) - compared to SAGA GIS 45 min and GRASS GIS 700 min. To
> use SLIC as Seed in i.segment it reduced the processing time to ~ 250
> min.
Both are good to hear. Thanks for the feedback !
> Is there any prospect to add the SLIC algorithm to i.segment as an
> option for "Segmentation method"?- It would be very cool to do
> multiscale/hierarchical segmentation with this algorithm.
The choice was to make this into a separate module, amongst others to
follow the general principle in GRASS that each module should do one
thing and only that (I know that with this logic, we probably should
have created i.segment.regiongrowing and i.segment.meanshift, but there
was sufficiently common code between the two to put them into one
module). We felt that the superpixel approach was different enough from
the other segmentation methods to warrant a separate modue.
When you speak of multiscale/hierarchical segmentation, what exactly are
you missing in i.superpixels.slic ? Some sort of "seeds" map as in
i.segment ?
> For curiosity, I also tried out your suggestion to use the Saga Seeds
> output modified by r.mapcalc "int_map = int(map)". However, during
> i.segment I received following Error-message: " ERROR: Invalid region
> id -3573".
That's weird. Does SAGA create negative segment ids ? Which outcome did
you use from the SAGA seed module ? For me it worked.
> Meanwhile, I also tested the i.segment.uspo add-on. It works fine -
> just the green progress bar does not.
No, I never implemented a progress measure in the module. A ToDo...
> Besides, manually, I calculated
> Moran's I and Intrasegment Variance by i.segment with 8 instead of 4
> neighbors (default). Even if the object looks kind of " pixelated" at
> the border, I received smaller Moran's I and Intrasegment Variance
> values with i.segment 8 NB in comparison to 4 NB (same settings for
> minsize and threshold). Maybe the "-d" flag of i.segment could also
> be added to i.segment.uspo...
That shouldn't be too difficult. Internally, i.segment.uspo uses the
addon r.neighborhoodmatrix which has a '-d' flag. I just really do not
have the time to implement this right now. You could try yourself by
opening the i.segment.uspo (or on Windows i.segment.uspo.py) file and
adding "flags='d'" to the call to r.neighborhoodmatrix (lines 535 and
following):
res = gscript.read_command('r.neighborhoodmatrix',
input_=mapname,
output='-',
sep='comma',
flags='d',
quiet=True)
This will always apply the flag. When I have time I can add this as a
flag to i.segment.uspo.
A slightly larger project I have is to actually extract the code for the
calculation of the spatial autocorrelation and create a
"r.spatialautocorrelation" module. But not now... ;-)
Moritz
