[GRASS-user] Question to the input seed grid of i.segment
Paulo van Breugel
p.vanbreugel at gmail.com
Fri Feb 10 10:15:25 PST 2017
On 10-02-17 18:41, Moritz Lennert wrote:
> Hi Raphael,
> On 10/02/17 12:08, Raphael Knevels wrote:
>> Hello Moritz,
>> thank you for your help, and sorry for my late response to this
>> topic.
>> The slic algorithm works really great :-) for my image (... which is
>> a slope) it needs around 27 minutes (11 000 superpixels and 0.6
>> compactness) - compared to SAGA GIS 45 min and GRASS GIS 700 min. To
>> use SLIC as Seed in i.segment it reduced the processing time to ~ 250
>> min.
> Both are good to hear. Thanks for the feedback !
>> Is there any prospect to add the SLIC algorithm to i.segment as an
>> option for "Segmentation method"?- It would be very cool to do
>> multiscale/hierarchical segmentation with this algorithm.
> The choice was to make this into a separate module, amongst others to
> follow the general principle in GRASS that each module should do one
> thing and only that (I know that with this logic, we probably should
> have created i.segment.regiongrowing and i.segment.meanshift, but
> there was sufficiently common code between the two to put them into
> one module). We felt that the superpixel approach was different enough
> from the other segmentation methods to warrant a separate modue.
> When you speak of multiscale/hierarchical segmentation, what exactly
> are you missing in i.superpixels.slic ? Some sort of "seeds" map as in
> i.segment ?
>> For curiosity, I also tried out your suggestion to use the Saga Seeds
>> output modified by r.mapcalc "int_map = int(map)". However, during
>> i.segment I received following Error-message: " ERROR: Invalid region
>> id -3573".
> That's weird. Does SAGA create negative segment ids ? Which outcome
> did you use from the SAGA seed module ? For me it worked.
>> Meanwhile, I also tested the i.segment.uspo add-on. It works fine -
>> just the green progress bar does not.
> No, I never implemented a progress measure in the module. A ToDo...
>> Besides, manually, I calculated
>> Moran's I and Intrasegment Variance by i.segment with 8 instead of 4
>> neighbors (default). Even if the object looks kind of " pixelated" at
>> the border, I received smaller Moran's I and Intrasegment Variance
>> values with i.segment 8 NB in comparison to 4 NB (same settings for
>> minsize and threshold). Maybe the "-d" flag of i.segment could also
>> be added to i.segment.uspo...
> That shouldn't be too difficult. Internally, i.segment.uspo uses the
> addon r.neighborhoodmatrix which has a '-d' flag. I just really do not
> have the time to implement this right now. You could try yourself by
> opening the i.segment.uspo (or on Windows i.segment.uspo.py) file and
> adding "flags='d'" to the call to r.neighborhoodmatrix (lines 535 and
> following):
> res = gscript.read_command('r.neighborhoodmatrix',
> input_=mapname,
> output='-',
> sep='comma',
> flags='d',
> quiet=True)
> This will always apply the flag. When I have time I can add this as a
> flag to i.segment.uspo.
> A slightly larger project I have is to actually extract the code for
> the calculation of the spatial autocorrelation and create a
> "r.spatialautocorrelation" module. But not now... ;-)
+1 (or make that a double plus) that would be really great!
> Moritz
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
