[GRASS-user] ... getting rid of duplicate polygons ...
    Huidae Cho
    grass4u at gmail.com
    Sat Feb 11 23:25:18 PST 2017
Uwe,
It wouldn't be easy to tell what your problem is without seeing your
dataset. If you don't want to share your dataset, maybe create a small
subset of it so others can try it.
Regards,
Huidae
On Fri, Feb 10, 2017 at 11:44 AM, Uwe Fischer <gisfisch at t-online.de> wrote:
> Hello list,
> I have a question about dealing with duplicate polygons (dp) coming into
> GRASS from a polygon shapefile. The polygons are not overlapping or having
> gaps, but there are a number of real duplicate ones (polygons show parcels
> with owners, and if one parcel has two or more owners, e. g. wife and
> husband, this situation in the shapefile is represented by two identical
> polys with two database rows that only differ in the owners name).
> My goal is to get rid of duplicates, having a result with only one
> polygon/centroid at a given location with only one owner name. The name
> does not matter, it can be chosen arbitrary by the system. This works fine
> when using ESRI "clean"-command. The structure of the database table is
> maintained while one (or many) of the dp is/are lost, leaving only one
> valid polygon.
> Now, I found an older thread called "unable to get rid of duplicate
> polygons". Obviously, the problem/question is the same but I could not find
> a solution for GRASS there. So I tried:
> v.clean -c input=input at mapset output=output_clean tool=snap,rmdac,bpol
> threshold=0.01,0,0
> and
> tool=break,snap,rmdupl,rmdac,bpol
> Nothing did work. I get a map with tree layers, one showing the islands
> only (layer 0), one showing the complete polygon set with duplicates (1),
> and one showing only the duplicates (2). I also tried to delete layer 2,
> assuming that this might remove the dp, but it only messed up the dataset.
> What am I doing wrong?
> Regards, Uwe
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170212/2934953d/attachment.html>
