[GRASS-user] error with imported kml file
Anna Petrášová
kratochanna at gmail.com
Sun Feb 12 12:44:28 PST 2017
On Sun, Feb 12, 2017 at 10:36 AM, Stuart Edwards <sedwards2 at cinci.rr.com>
wrote:
> Hi -
> I have imported a kml file that contains contours of a feature of
> interest. Functionally an x,y,z data set. It displays correctly in GRASS.
> When queried to determine the value of z, the attached error is given that
> indicates a lack of conformance with JSON formatting. The values of z are
> given for the feature in the error message but additional processing such
> as v.to.rast does not work. GRASS is able to label the contours correctly.
> Using the attribute table manager is not much help - it produces an error
> that indicates 'Inconsistent number of columns in table'.
> I see that there is a bug report (3133) that reflects the same problem but
> has been fixed in 7.0.5 - I'm getting the 'same' error in 7.3.svn. (on OS X
> 10.10.5)
> The error message is too long to fit on the monitor - and is not
> scrollable, so the full content is not visible.
> Any assistance or advice much appreciated.
> please post (or attach) the text outputs of v.what with -j flag and
v.db.select, which are the backend commands behind the GUI dialogs. That
helps us to analyze it.
Anna
Stu
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170212/0914ada0/attachment-0001.html>
Name: Screen Shot 2017-02-12 at 10.29.33 AM.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170212/0914ada0/attachment-0001.png>
