[GRASS-user] Creating STRDS from scratch
Rich Shepard
rshepard at appl-ecosys.com
Wed Feb 22 07:28:35 PST 2017
On Tue, 21 Feb 2017, Laurent C. wrote:
> In your case, it seems you want to have uniform rainfall. So you can set
> the region, and then use mapcalc like so: r.mapcalc
> exp='rainfall_2013115=0.1' And doing the same for each day.
The region is correctly set. I assume that what t.info reports is correct
as the rainfall input to Itzi and would like confirmation or corrections:
t.info type=strds input=rainfall
+--------------- Space Time Raster Dataset ---------------------------+
+--------------- Basic information -----------------------------------+
| Id: ........................ rainfall at topography
| Mapset: .................... topography
| Creator: ................... rshepard
| Temporal type: ............. absolute
| Creation time: ............. 2017-02-21 13:43:48.931376
| Modification time:.......... 2017-02-21 13:43:48.931422
| Semantic type:.............. mean
+--------------- Absolute time ---------------------------------------+
| Start time:................. None
| End time:................... None
| Granularity:................ None
| Temporal type of maps:...... None
+--------------- Spatial extent --------------------------------------+
| North:...................... None
| South:...................... None
| East:.. .................... None
| West:....................... None
| Top:........................ None
| Bottom:..................... None
+-------------- Metadata information ---------------------------------+
| Raster register table:......
raster_map_register_7137018d99ba4dd29f94b620b8ca406e
| North-South resolution min:. None
| North-South resolution max:. None
| East-west resolution min:... None
| East-west resolution max:... None
| Minimum value min:.......... None
| Minimum value max:.......... None
| Maximum value min:.......... None
| Maximum value max:.......... None
| Aggregation type:........... None
| Number of registered maps:.. None
| Title:
| Rainfall Rates
| Description:
| Daily rainfall rates in mm/hr.
| Command history:
| # 2017-02-21 13:43:49
| t.create type="strds" temporaltype="absolute"
| output="rainfall" title="Rainfall Rates"
| description="Daily rainfall rates in mm/hr."
Rich
