[GRASS-user] Creating STRDS from scratch
Sören Gebbert
soerengebbert at googlemail.com
Wed Feb 22 07:37:11 PST 2017
This is a good looking empty STRDS. All metadata that is set to "None"
will be updated if maps are added to the STRDS with t.register.
2017-02-22 16:28 GMT+01:00 Rich Shepard <rshepard at appl-ecosys.com>:
> On Tue, 21 Feb 2017, Laurent C. wrote:
>> In your case, it seems you want to have uniform rainfall. So you can set
>> the region, and then use mapcalc like so: r.mapcalc
>> exp='rainfall_2013115=0.1' And doing the same for each day.
> The region is correctly set. I assume that what t.info reports is correct
> as the rainfall input to Itzi and would like confirmation or corrections:
> t.info type=strds input=rainfall
> +--------------- Space Time Raster Dataset ---------------------------+
> +--------------- Basic information -----------------------------------+
> | Id: ........................ rainfall at topography
> | Mapset: .................... topography
> | Creator: ................... rshepard
> | Temporal type: ............. absolute
> | Creation time: ............. 2017-02-21 13:43:48.931376
> | Modification time:.......... 2017-02-21 13:43:48.931422
> | Semantic type:.............. mean
> +--------------- Absolute time ---------------------------------------+
> | Start time:................. None
> | End time:................... None
> | Granularity:................ None
> | Temporal type of maps:...... None
> +--------------- Spatial extent --------------------------------------+
> | North:...................... None
> | South:...................... None
> | East:.. .................... None
> | West:....................... None
> | Top:........................ None
> | Bottom:..................... None
> +-------------- Metadata information ---------------------------------+
> | Raster register table:......
> raster_map_register_7137018d99ba4dd29f94b620b8ca406e
> | North-South resolution min:. None
> | North-South resolution max:. None
> | East-west resolution min:... None
> | East-west resolution max:... None
> | Minimum value min:.......... None
> | Minimum value max:.......... None
> | Maximum value min:.......... None
> | Maximum value max:.......... None
> | Aggregation type:........... None
> | Number of registered maps:.. None
> | Title:
> | Rainfall Rates
> | Description:
> | Daily rainfall rates in mm/hr.
> | Command history:
> | # 2017-02-21 13:43:49
> | t.create type="strds" temporaltype="absolute"
> | output="rainfall" title="Rainfall Rates"
> | description="Daily rainfall rates in mm/hr."
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
