[GRASS-user] t.register does not register anything in a STVDS
Sören Gebbert
soerengebbert at googlemail.com
Thu Feb 23 19:27:38 PST 2017
You need to specify the name of the stvds in t.register.
Am 24.02.2017 02:48 schrieb "Laurent C." <lrntct at gmail.com>:
> Hello,
> I created an empty STVDS that looks fine:
> t.info input=water_levels_20150801 at kolkata type=stvds
> +-------------------- Space Time Vector Dataset
> +-------------------- Basic information ------------------------------
> | Id: ........................ water_levels_20150801 at kolkata
> | Name: ...................... water_levels_20150801
> | Mapset: .................... kolkata
> | Creator: ................... laurent
> | Temporal type: ............. absolute
> | Creation time: ............. 2017-02-23 19:18:15.120512
> | Modification time:.......... 2017-02-23 19:18:15.120516
> | Semantic type:.............. mean
> +-------------------- Absolute time ------------------------------
> | Start time:................. None
> | End time:................... None
> | Granularity:................ None
> | Temporal type of maps:...... None
> +-------------------- Spatial extent ------------------------------
> | North:...................... None
> | South:...................... None
> | East:.. .................... None
> | West:....................... None
> | Top:........................ None
> | Bottom:..................... None
> +-------------------- Metadata information ------------------------------
> | Vector register table:......
> vector_map_register_c14262576ea94a78a55b48b65a72b3a6
> | Number of points ........... None
> | Number of lines ............ None
> | Number of boundaries ....... None
> | Number of centroids ........ None
> | Number of faces ............ None
> | Number of kernels .......... None
> | Number of primitives ....... None
> | Number of nodes ............ None
> | Number of areas ............ None
> | Number of islands .......... None
> | Number of holes ............ None
> | Number of volumes .......... None
> | Number of registered maps:.. None
> | Title:
> | water_levels
> | Description:
> | Command history:
> | # 2017-02-23 19:18:15
> | t.create --overwrite output="water_levels_20150801"
> | type="stvds" semantictype="mean" title="water_levels" description="
> I have a maplist file in the form:
> water_levels_20150731000000|2015-07-31 00:00:00
> water_levels_20150731001500|2015-07-31 00:15:00
> [snip]
> water_levels_20150801233000|2015-08-01 23:30:00
> water_levels_20150801234500|2015-08-01 23:45:00
> The vector maps look sane:
> v.info map=water_levels_20150731021500 at kolkata
> | Mapset: kolkata
> | Location: UTM45N
> | Database: /home/laurent/grassdata
> | Title:
> | Map scale: 1:1
> | Name of creator: laurent
> | Organization:
> | Source date: Thu Feb 23 18:50:06 2017
> | Timestamp (first layer): 31 Jul 2015 02:15:00
> | Map format: native
> | Type of map: vector (level: 2)
> | Number of points: 3 Number of centroids: 0
> | Number of lines: 0 Number of boundaries: 0
> | Number of areas: 0 Number of islands: 0
> | Map is 3D: No
> | Number of dblinks: 1
> | Projection: UTM (zone 45)
> | N: 2495814.59574642 S: 2492825.11903619
> | E: 645063.06070329 W: 641365.09898322
> | Digitization threshold: 0
> | Comment:
> t.register seems to works fine:
> t.register --overwrite --verbose type=vector
> file=/home/laurent/Datos_geo/kolkata/one_rainfall_event_of_
> 2015/wl_register_list.txt
> Gathering map information...
> Registering maps in the temporal database...
> But no map is added to the STVDS. If I run t.info again, I get the
> exact same results as above.
> Strangely, if I run t.register without the --overwrite flag, I get the
> following error:
> t.register --verbose type=vector
> WARNING: Map is already registered in temporal database. Unable to
> update vector map <water_levels_20150731000000 at kolkata>. Overwrite
> flag is not set.
> [snip]
> But again, t.info or t.vect.list don't show any map.
> By opening the SQLite DB, I can see that:
> - the vector maps appear in 'vector_spatial_extent', with the extent
> filled-up
> - the vector maps appear in 'vector_absolute_time', with the correct
> start time
> - the values in 'vector_metadata' seem correct
> - the vector maps appear in 'vector_stds_register', but the column
> 'registered_stds' is empty
> Is there something I'm missing?
> Regards,
> Laurent
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
-------------- nächster Teil --------------
Ein Dateianhang mit HTML-Daten wurde abgetrennt...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20170224/6efb0b0d/attachment.html>
